Need help ordering Piston Rings
Old Jun 26, 2022 | 06:28 PM
Sr94's Avatar
Sr94
Default Need help ordering Piston Rings
Hello I’m rebuilding my Revup due to excessive smoke from the rings. I had just one question, In the service manual it says the Top and 2nd ring gap in cylinder should be between 0.23 - 0.33mm with a 0.54mm Limit (idk what this means) I am getting a measurement of 0.45mm for both rings. Should I order oversized rings or would I just go with standard size. I have yet to hone the block yet.
Thank you,
Old Jun 27, 2022 | 06:19 AM
iideadeyeii's Avatar
iideadeyeii
A new ring should be within the first specs. The limit is the wear limit
Old Jun 27, 2022 | 08:12 AM
Sr94's Avatar
Sr94
Thanks! That makes sense thanks for the clarification. Do you think the standard would put me in spec?
citymunky
Sep 6, 2011 08:33 AM
jmicaelk
Mar 30, 2011 01:59 PM
Z350Lover
Nov 29, 2005 12:53 PM
GY-Z
Feb 29, 2004 03:09 PM
