Serious problem with my 07 HR, NEED HELP!!!
Old Aug 29, 2022 | 11:12 AM
NicoPz's Avatar
NicoPz
Default Serious problem with my 07 HR, NEED HELP!!!
My car started to did this today
This problem is only when i drive the car for 20-30 minutes, first those lights come on, then all the windows, lights and cluster stop working, then the car turn off and i need to wait it to cool down, then again runs normal just for a few time.
Someone with the same problem?
The scanner only shows the code P0550 (Power Steering) but i dont think this affects in the main problem.
For reference, MAF´s were changed recently because the problem was similar but with the MAF the car is turning on perfect, then the problem presents after those 30 minutes,
Do you think the problem could be the BCM? Or the crank and cam sensors?
Thank you in advance
File Type: mov
File Type: mov
Old Aug 29, 2022 | 06:12 PM
icer5160's Avatar
icer5160
Sounds like a potential wiring fault. Usually, if you have a bad crank or cam sensors, you would see other codes. Many of these sensors get a 5V reference signal directly from the ECU. ECU failures are very rare, so I would start running through the FSM wiring diagrams and start checking voltages and continuity before firing the parts canon.
-Icer
Old Aug 30, 2022 | 06:51 AM
NicoPz's Avatar
NicoPz
Thank you very much, i will check all the lines first, will keep you updated.
Vasquez33
Feb 7, 2016 11:42 AM
The_Assassin
Jun 5, 2013 09:46 AM
Bryan H
Mar 31, 2010 09:34 AM
tjones278794
Sep 13, 2007 04:00 AM
ephilyawjr
350Z Roadster
Oct 20, 2003 11:05 AM
