Fender rolling
Old 11-22-2022, 10:41 PM
Oz33
Oz33's Avatar
Default Fender rolling
Aloha, I was woundering if I would need to roll my front fenders besides my rear my tire set up is 9.5 with a 265/35/18 and a 10.5 with a 275/35/18 +15 all around. I’ve recently purchased coilovers and I wanna give my car the tucked look to it but with that being said I really don’t wanna have to roll my fronts and have to pull of my liner. Any advice would help thanks.
Old 11-23-2022, 01:25 AM
MatthewBouchard
MatthewBouchard's Avatar
Same setup except 285 rear. On eibach Sportline springs, I didnt touch the front fenders/liners.
Old 11-23-2022, 09:38 AM
bre240z
bre240z's Avatar
i have 18x9.5 +15 255/40 up front with no issues. Im on TEIN coilovers did not roll fronts. Get everything on and see what happens before you roll
Old 11-23-2022, 09:52 AM
travlee
Master
travlee's Avatar
Received 9,126 Likes on 6,579 Posts
Front are rolled from factory, you would have to pull them
Old 11-23-2022, 12:45 PM
Oz33
Oz33's Avatar
is it tucking ?
Old 11-23-2022, 12:47 PM
Oz33
Oz33's Avatar
yeah I felt the lip but I was thinking about fully rolling them in if need be which I don’t want
Old 11-23-2022, 12:49 PM
Oz33
Oz33's Avatar
I’ll full max my front coils and see where it’s at. But is your front wheels tucking in the fenders aswell ?
Old 11-23-2022, 01:24 PM
bre240z
bre240z's Avatar
Not the best picture but this is how my Z sits right now
Old 11-23-2022, 01:30 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,285 Likes on 2,337 Posts
Tires this short will defeat the purpose of "tucking" in when the tires are so short they create wheel gap.
OE diameter is 25.97 and 26.68 F-R. Your suggested sizes are 25.30 and 25.58 F-R.
Use 255/40-18. 275/40-18 on those +15 wheels. You will almost certainly need to roll n' seal the rears with +15s unless you go up to a +22 to +25 rear offset.
Fronts, if you go 265/40, you will likely need to remove the liner screw at top. And, since there's no upper lip to roll for clearance, pulling is the only option. There are lips F&R that can be rolled for clearance but look like crap and you shouldn't ever need to roll those with reasonable suspension/alignment and proper tires. Only time you would likely need to clearance those lips is you're running exterme drift angles then who cares what it looks like since its going to get destroyed anyways. Get the right size tires/wheels to start.and forget about fender mods.
user 92720
07-19-2011 01:19 PM
big_scoggs
05-10-2011 11:55 AM
swampy56
09-05-2008 01:23 AM
komodo350
02-17-2008 05:51 PM
emulzhn
03-12-2007 03:20 PM
Quick Reply: Fender rolling
