Failed Emissions pretty badly! HR Z
Old Nov 23, 2022 | 06:26 AM
redslash2000's Avatar
redslash2000
Default Failed Emissions pretty badly! HR Z
Hey guys,
My 2008 350z has just gone through an mot and failed on its emissions.
It’s failed on the natural idle, fast idle and second fast idle. All of these are CO failures, the lambda and HC tests were fine.
the natural idle was only 0.01 off passing so I feel like with an Italian tune up, it would probably pass there. The issue is on both the fast idle tests, I failed by 0.44 and 0.72 which seems extremely high
I’ts on 120k miles and the previous owner had the back box deleted, however this shouldn’t effect emissions right?
Could anyone point me in the right direction, I honestly haven’t a clue where to begin!
Cheers.,
Old Nov 23, 2022 | 02:03 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by redslash2000
Hey guys,
Cheers.,
ls the car showing any DTCs? Doing so should at least point in a direction to look.
Old Nov 24, 2022 | 04:06 AM
redslash2000
just done a scan of the car and the only fault present appears to be P2A00 - guessing first port of call would be to replace the sensor and see where I’m at?
Old Nov 28, 2022 | 06:09 AM
kshaw's Avatar
kshaw
Yes, replace the oxygen sensor. If you have a high end scanner, it will graph operation of the oxygen sensor. If the idle still does not perform properly, take off the idle control valve and clean with Seafoam throttle body cleaner.
Old Nov 28, 2022 | 06:56 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Please define "Italian tune up" for us yanks?
Old Nov 28, 2022 | 10:19 AM
Heel Til I Die's Avatar
Heel Til I Die
I always heard an Italian tune-up was going WOT to the redline - allegedly cleaning out built-up deposits.
That's what a certain parent would always tell me when I was a kid and we were riding around in the not-so-family-friendly Alfa Spider. I think maybe it was just an excuse...
JDMStanced
May 17, 2011 08:38 PM
marco_mendoza
Oct 26, 2010 06:21 AM
shadykilla717
Jan 14, 2008 02:54 PM
gtbuzzbee
Aug 23, 2003 09:53 PM
