Mice ate fuel pump wires - What can I plug the area with ?
Behind the drivers seat and behind the stock Bose Sub woofer is a compartment with a "trap door". Remove 4 bolts and the trap door cover can be removed to get at the fuel pump (and wiring).
Unfortunately, mice can get up into this area from beneath the 350Z.
(Without the cover in place, road noise is loud.)
I am thinking about stuffing insulation or some type of barrier everywhere under the fuel pump cover to prevent mice from getting in there . . . . and to perhaps quite everything somewhat.
Comments or suggestions ?
Thanks.
Thanks.
I think ya'll are under-estimating the rodents, if they want to get in they WILL get in. They can gnaw through almost anything and can fit through holes the size of a nickel.
For those reasons I'd go with chicken wire and mothballs and an adopted cat from a shelter. GL!
350Z/370Z Tech Moderator
Used to plug kitchen drain holes in cabinetry with steel wool. Was effective for that, not sure about in an area where there's electrical connections though. Then again, a mouse, an electrical connection nearby.... sounds intriguing. I can already hear Emeril shouting "BAM!"
I like the steel wool idea. Perhaps stainless steel.
I considered spray foam but it’s messy and a little too permanent.
https://www.amazon.com/Stainless-Ste.../dp/B01N9LUEUJ
Update . . . . .
There was a time when my car was parked outside and open to the possibility of mice damage. Not anymore, she is safe in my basement.
However, I recently discovered that mice had (at one time) built a nest under my battery tray. This is a very dangerous area for mice damage because of all the battery and other wires that are in there. I only discovered it when I had to remove the battery tray. Fortunately only 2 of my wires had slight damage, and It was easy to repair.
I am posting this only to possible help someone who may have mice or electrical gremlins.
