15,000 mile tune up question
Old Feb 26, 2004 | 12:33 PM
Moodie's Avatar
Moodie
Minivan Racer
Default 15,000 mile tune up question
Apart from inspections, checks, and oil and filter changes, dealer suggest I also get my fuel injectors flushed for an extra $100. Should I do it???
Old Feb 26, 2004 | 12:41 PM
wren57's Avatar
wren57
Hah, no... go to an auto parts store and buy some fuel injector cleaner additive and put it in your gas tank...
Old Feb 26, 2004 | 12:48 PM
Moodie's Avatar
Moodie
Minivan Racer
Default Is it really that simple?
What a rip off if that's the case......
Old Feb 26, 2004 | 01:02 PM
samw1978's Avatar
samw1978
it's ridiculous! Don't do it!
Old Feb 26, 2004 | 01:08 PM
350zluvr's Avatar
350zluvr
I just had my 7500 mile service done and seriously wished I hadn't flushed all that money down the drain for no apparent reason.
Now I'm confused about the 15,000 mile service. What does it involve and what do we NEED to get done?
Old Feb 26, 2004 | 01:10 PM
Moodie's Avatar
Moodie
Minivan Racer
Default From my understanding.....
Oil change, transmission oil change, air filter change, they check the tires, inspect the brakes and other misc. checks.
Am I correct?
Old Feb 26, 2004 | 04:45 PM
bigdaddy's Avatar
bigdaddy
my dealer only charged me for the oil change and my yearly state inspection at my 12month/15000 mile service. she said "we realized your car doesn't really need anything but the oil change, the inspection, and our normal once-over. it really doesn't make sense to charge you for the entire $150 (or whatever it was) for the service when you don't need it all."
maybe you can get your dealer to do the same.
oh...the injector thing is a definate scam.
sean
Old Feb 26, 2004 | 05:08 PM
FB-350's Avatar
FB-350
just had my 15k service done...
initial price was $239 - but after my service rep went down the list of things to do, half of them i didn't need...
i.e. i've got aftermarket wheels/tires, so i certainly wasn't going to let them do the tire rotation, and i've got the popcharger, so i didn't need a new air filter....
basically, i paid about $150 for an oil change, coolant flush, chassis lube ( ), and their once over on the belts, hoses etc, which i pretty much do weekly..... i didn't get the injector question however...
i must say the coolant flush was worth it though - the temp gauge reads noticeably cooler than it used to.....
Old Feb 26, 2004 | 08:42 PM
vonsudderth's Avatar
vonsudderth
Stay away from injector cleaning unless you have reduced flow. The injectors do not repond well to caustic cleaners and unless they are plugging up I would not recomment it
Old Feb 26, 2004 | 09:24 PM
Moodie's Avatar
Moodie
Minivan Racer
Default Thanks for the responses, guys.....
I know this board is very helpful......
Old Feb 28, 2004 | 05:33 PM
FrankieZZ's Avatar
FrankieZZ
Owners manual says NO injector additives ,you could do more harm than good . Also , if you have any experience with cars , dealers , and service intervals ,you would already have the answer .
Old Feb 28, 2004 | 05:47 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
I love this board....but did I miss something?
I have 12K miles and have never had any service/inspection.
Is there a 7500 mi service?
Old Feb 29, 2004 | 02:22 AM
FrankieZZ's Avatar
FrankieZZ
EnthuZiast ,
You didn't miss a thing . Keep up the good work and your Z will last forever !
Old Feb 29, 2004 | 06:43 AM
Boomer's Avatar
Boomer
You are supposed to get the oil changed at a minimum at 7500 for warranty compliance. There are 3 levels of service. 1 is totally ridiculous unless you want to throw your money away. 2 is reasonable for 15,000 mile intervals and 3 really isn't enough for me. Its very bare bones. If you are a DYIer, you can do 15,000 mile intervals your self. I'm not, but I will change my oil and filter with Mobile 1 every time I have 5000 miles or 6 months on it. At 30,000, I will have the Level 1 service done because I'm only putting on 7000-8000 miles on in a year.
Just don't do an oil flush, its not necessary, unless you have 90,000 miles on your car. Even then, if you are putting in fresh oil and a filter at more than manufacturer recommendations, its still probably overkill.
Old Feb 29, 2004 | 06:50 AM
EddieJr's Avatar
EddieJr
Every owners manual says that, I've yet to see a fuel injector damaged from off the shelf injector cleaner.
Old Feb 29, 2004 | 02:11 PM
Scrapin 240's Avatar
Scrapin 240
i had read that on the Z32 that the fuel injector cleaners had caused the fuel tank to rust. but apart from that. i too have never seen them do any damage.
My dealer had a maintenace schedule and for 7500 and 15000 they want like $239 or $269 to do service at those intervals. like system cleaner and all kinds of things. ummm how about no.
Old Feb 29, 2004 | 03:35 PM
Boomer's Avatar
Boomer
I always check the maintenance schedule in the owner's manual before any work is done. Anything not on it is an immediate no. Cars today need a lot less maintenance than ones from prior decades. Change the oil/filter and flush and refill the cooling sysytem are the core services. Many of the other services are just check and rarely need even a top off. I am not recommending they not be done, I do them, but not every 3750 miles, thats just wasteful.
Old Feb 29, 2004 | 09:12 PM
Moodie's Avatar
Moodie
Minivan Racer
Default You guys are good.....
When I buy a new car, I hardly read the owners manual. I just drive, drive, and drive......
Old Mar 1, 2004 | 05:12 AM
mcduck's Avatar
mcduck
Wow! You guys are tight... my 15000 mile service cost me a LOT more than $100...
Of course, my service consisted of the usual... plus Nismo Cam install... plus header install... plus Crawford plenum install... plus UR Pulley install... and a few other goodies!
Old Mar 1, 2004 | 01:03 PM
PerfZ's Avatar
PerfZ
Is there a 7500 mi service? [/B][/QUOTE]
Despite repeated reminders from the dealer, I did the 7500 myself - oil/filter and air filter. A little lithium grease on the hinges and topped off the fluids. "Bout an hour total, most of which was removing the bottom pan. Oh, and the oil filter turned off by hand, and really easily at that. Keep it away from your dealer whenever possible! Of course it helps to have a friend with a heated 4-stall pole barn (who just happens to store his cherry '73 'Vette in it)
