Whiteline diff bushing issue
Old Apr 4, 2023 | 08:20 PM
thebomb2644's Avatar
thebomb2644
Default Whiteline diff bushing issue
This is gonna a head scratcher....so I took a vid of my whiteline diff bushing and In basic words it is moving up and down like a blown oem rubber bushing.There is nothing visually wrong with the sleeve is still bonded with the poly and is sitting flush with the diff cover. I checked the other bushings as well and even up to my trans mount and everything checks out. Not really sure what's wrong here and am kinda frustrated because my poly bushing is deflecting like a blown oem one. Any idea?
Old Apr 5, 2023 | 05:04 AM
Heel Til I Die's Avatar
Heel Til I Die
There's going to be some movement. Can you post the video? Is everything torqued down to spec?
Old Apr 5, 2023 | 07:03 AM
i8acobra's Avatar
i8acobra
The poly bushing is supposed to move. It's stiffer than OEM and it's not fluid filled, so it will never leak. It's not supposed to be solid.
Old Apr 5, 2023 | 10:26 AM
icer5160's Avatar
icer5160
If you want to minimize movement further without adding NVH, look into a diff brace. If NVH is not a concern, then go with solid bushings. I'm running with Whiteline diff bushings + Gktech diff brace, this combination in my opinion, is very good for street use. I have not noticed any additional NVH. Little to no slop in the drivetrain compared to stock setup. I'm very happy with it. Note that the front, side (L & R) whiteline diff bushings should have the thicker halves on top, against the body of the car. The Whiteline instructions from years ago depicts the thicker halves installed on the bottom, which is incorrect. It appears that Whiteline has since removed these instructions from their website (link is broken), but you can still find the old sheet if you dig enough.
Cheers!
-Icer
Old Apr 5, 2023 | 11:20 AM
thebomb2644
Yea here it is
Old Apr 5, 2023 | 11:24 AM
thebomb2644
Everything is torqued to spec and nothing is loose. In the video I was in first gear on and off throttle around 3500 rpm so pretty torque heavy situation
Old Apr 5, 2023 | 10:34 PM
icer5160's Avatar
icer5160
Yeah, that's pretty normal movement. Nothing defective/broken there, also nowhere near as bad as a blown OEM bushing.
Cheers!
-Icer
Old Apr 6, 2023 | 04:15 AM
Heel Til I Die
Agreed. Looks fine. I bet you're no longer getting that "clunk" during hard shifts like you would with a blown OEM bushing.
plaight
Drivetrain
Oct 18, 2017 07:34 AM
CFS_Z
May 10, 2017 11:10 PM
cashmoney03
Mar 7, 2015 08:55 AM
Itzcashew
Jun 25, 2012 10:55 PM
tw8715
Jan 15, 2012 08:44 PM
