USB install from rear of stereo
Old Jun 18, 2023 | 09:58 AM
streamin350's Avatar
streamin350
Default USB install from rear of stereo
Just wondering if their is enough space to fit the USB faceplate referenced below in cubby storage above radio? Anybody try that?
Old Jun 18, 2023 | 10:06 AM
DarkZ03's Avatar
DarkZ03
Probably not if you want it installed on the back "wall" there is stuff behind it.
Old Jun 18, 2023 | 10:23 AM
streamin350
I was thinking the same thing. Maybe the sides would be more room.
Old Jun 20, 2023 | 05:38 PM
icer5160's Avatar
icer5160
Don't hack up your dash or cubby. Replace the 12V outlet on the passenger side lower dash panel instead. There's a few vendors that make plug and play adapters that fit perfectly. I prefer the Scosche unit. Looks cleaner/stealthy, no need to cut holes! I made a post you can find here.
Cheers
-Icer
Old Jun 21, 2023 | 04:53 PM
streamin350
I have a cup holder there. looks like something for a lighter
Old Jun 21, 2023 | 06:50 PM
icer5160's Avatar
icer5160
The cup holder is higher up on the same panel, some vehicles have a small change or business card drawer instead of the cup holder (which is how mine came equipped). Honestly I'm not 100% sure what those little pop out drawers are for. They are so small, it's almost pointless (I'm sure Mic knows). At the very bottom of the panel there should be a flip down cover that exposes the 12V outlet. Yes, on older vehicles (pre-90s) these were primarily used for cigarette/cigar lighters (I still remember my brother's 1984 Lincoln Continental with these in the door arm rests). The 350Z did not come with the push button lighter, it's just a metal barrel with 12V power for plug-in accessories. There should be another 12V outlet behind the center armrest pocket (also with cover flap). No one really uses the passenger footwell 12V outlet in 350Zs, and if they do, they typically use it for phone charging. The adapter I mentioned still maintains phone charging capabilities, but also doubles as a USB data port for connection to a head unit.
Anyway, it was just a mere suggestion from one Z owner to another. If you prefer to drill and mount elsewhere in your Z, by all means. But I don't believe there's enough clearance for the adapter you linked to mount inside the center waterfall cubby (back wall, sides, top, or bottom). Depending on the year and trim of your Z, you could mount it at the center console, on the blank cover panel between cup holders and shifter bezel (Caveat: Must not have leather heated/power seats). I had this same adapter once upon a time and that's where I put it since the blank cover is cheap and easily replaced if you want to cleanly remove the USB port in the future. The switch dividers will need to be broken out for this though, which shouldn't be a problem if you never had switches to begin with. Other places aren't nearly as convenient, such as the glovebox , but would require a USB extension cable and the need to move the passenger seat whenever you wanted access. The same is true for the other smaller, upper storage pockets behind the seats. The center armrest compartment sits close to the transmission tunnel and SRS module for mounting at the bottom, but the back wall might work, I haven't verified this myself.
Cheers!
-Icer
Old Jun 23, 2023 | 06:27 AM
Heel Til I Die's Avatar
Heel Til I Die
I mounted a similar looking USB socket (it has a USB and 3.5mm aux input) on the front wall of the center armrest compartment under the storage lid. I can snap a pic if OP (or anyone) is curious as to the placement.
Old Jun 23, 2023 | 11:43 AM
icer5160's Avatar
icer5160
Hi Heel,
I'm interested, please share.
Cheers!
-Icer
Old Jun 25, 2023 | 12:50 PM
streamin350
That would be great. I took out my center console to see where I can run the USB wire and location of the hole.
Old Jun 26, 2023 | 05:29 AM
Heel Til I Die
Sorry no pictures during the install, but here is the finished product. It fits pretty nicely right there in the middle of the business card holder (which I have never used).
ivanito
Jan 7, 2006 08:48 AM
d!abolic
Dec 19, 2005 10:30 AM
dza00
Sep 16, 2005 06:28 PM
Anomaly460
May 4, 2005 03:23 PM
