Possible issue with Abs sensor or brake fluid pump
Old Jul 24, 2023 | 04:49 AM
Wayne350Z's Avatar
Wayne350Z
Default Possible issue with Abs sensor or brake fluid pump
Hi I have a 2005 Nissan 350Z De engine and recently when I give it a bit of gas and traction activates the slip, traction, abs and brake lights turn on and they don’t turn off unless the car is left switched off for a long time. Once its switched off it also starts making like a small vibration sound from near the brake fluid container area. Does anyone please have an idea what this issue may be and how I can resolve it. Thanks.
Old Jul 24, 2023 | 05:01 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- the first item to try is to access the Z's onboard diagnostic system via the OBD2 port. There may be a code held in memory that will help you diagnose which system (or part) is malfunctioning. Buying or accessing a code reader is a must for the new Z car owner.
dklau33
Jan 30, 2023 05:52 AM
kihun
Jun 2, 2011 11:57 AM
onagao
Sep 25, 2010 12:35 PM
widebody350
Mid-Atlantic
Dec 31, 2009 02:12 PM
