350z Wheel Hub/Adapters
Old Aug 11, 2023 | 11:07 AM
Tech Territory's Avatar
Tech Territory
Default 350z Wheel Hub/Adapters
Hello! So I bought a set of wheel spacers to adapt the 5x114 to 5x120 for a set of wheels that I just bought, and once I got the spacers I tried to test fit them, and they fit fine, but the hub for the Z was smaller than the size of the hub for on the adapters… I don’t think i should use them, because i’m pretty sure the hub is supposed to fit snug, right?? if I could get some insight here that would be great thanks! and also if these hubs shouldn’t be used, a link to some that should be used
Old Aug 11, 2023 | 11:20 AM
Heel Til I Die's Avatar
Heel Til I Die
Definitely do not use those adapters. The load should be on the hub which has a bore size of 66.1.
I wouldn't use those adapters at all, but if you must, get some hub rings that convert the 66.1 to whatever the bore size of your adapters is. Kind of similar to hub rings for aftermarket wheels that don't have a 66.1 hub.
Old Aug 12, 2023 | 02:16 PM
Tech Territory
okay perfect thanks
Old Aug 12, 2023 | 03:34 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
I've no personal experience with adapting BMW (presumably) wheels to a Z but have used many spacers from this company on fleabay.
These have the right hub hole measurement (66.1) but, mind the wheel offsets as these will drop offset by 25mm. I believe they offer a slimmer version, maybe like 20mm instead of these 25s. Either way, unless you're using the +40 offset Bimmer wheels, these might cause clearance issues if you plop these behind the typical +20 wheels they offer.
Old Aug 12, 2023 | 05:45 PM
Tech Territory
the wheels I bought are +32mm offset and I beleive that the stock offset is +22mm, so a -25mm (1 inch) spacer would make it a +7mm offset, which I believe would stick out quite a bit... thoughts?
Old Aug 12, 2023 | 05:47 PM
Tech Territory
Also are the studs the correct thickness/thread?
Old Aug 12, 2023 | 06:06 PM
Tech Territory
Default 5x114.3 66.1mm to 5x120 72.6mm hub adapter?
Hello! I have a 2003 Nissan 350z Touring Hatch, and I just bought a set of KLÄSSEN iD wheels that the previous owner had on his BMW M2, and I cannot seem to find a set of adapters that match my 350z's hub specs (66.1mm hub, 5x114.3 bolt pattern, M12x1.25 thread size) that can also adapt to the KLÄSSEN iD Wheels (72.6mm hub, 5x120 bolt pattern, M14x1.25 thread size) can I get some help??? I dont want any poke really, so the smallest adapter possible would be appreciated, so probably about 20mm thick (Less is also great, havent found any though)
Anyways, I really need some help, new to this all, and I cannot seem to figure it out, sorry guys, probably super easy to find, but im having a heck of a time
Old Aug 12, 2023 | 08:06 PM
MicVelo's Avatar
i have no clue, You gave zero wheel specs.
Did you search them out on eBay? There are Nissan specific sets.
Old Aug 12, 2023 | 08:17 PM
MicVelo's Avatar
*****THREAD MERGED WITH DUPLICATE*****
Is there an echo in here?
I answered this twice already.
One more time..... ebay vendor has the hub centric adapters; then, you buy 72.6 to 66.1 hub rings.
All while minding size, offsets, and lug/wheelnut type (note that earlier Bimmers all used wheel BOLTS so you'll have to find a set of lug nuts with the same seat angle). No clue why you bought BMW spec wheels when there are far more 5x114.3 properly sized wheels than 5x120 but whatever.
Old Aug 13, 2023 | 01:43 PM
travlee's Avatar
travlee
Master
Parking lot swag points....that why he bought the wrong wheels
Old Aug 13, 2023 | 01:53 PM
Tech Territory
Sorry, totally my bad, i guess i didnt really understand, all of this is new to me, but yeah, I got it, buy a set of 5x114.3 to 5x120 adapters with a bore of 72.6 and then buy a set of 72.6 to 66.1 adapter rings to fit the spacers to the hub of my Z
and I bought them because they were a crazy deal, and the guy gave me a set of racing slicks and Nitto NT01's
Old Aug 13, 2023 | 01:57 PM
Tech Territory
also how should I attatch the adapter to the hub if the thread isnt the same size?
Old Aug 13, 2023 | 02:12 PM
travlee's Avatar
travlee
Master
Easy.....sell them and buy proper wheels
Old Aug 15, 2023 | 12:46 PM
Tech Territory
Thanks man :|
Old Aug 15, 2023 | 12:58 PM
travlee's Avatar
travlee
Master
Just being honest...why rig when you do it right?
Old Aug 15, 2023 | 05:33 PM
Tech Territory
because im a 15 year old that has literally no money right now, trying to earn money working at chick fil a, i got a good deal on this set of wheels, and ill do it right eventually, but i cant right now
Old Aug 15, 2023 | 05:49 PM
travlee's Avatar
travlee
Master
What do you consider a good deal?
Old Aug 15, 2023 | 07:05 PM
Tech Territory
$500 for a whole set of only track used, not at all curb rashed, 10.5 wide ID Klassen Wheels that come with a whole set of 25% used racing slicks, and Nitto NT01s that have about half of the tread left. Sound like a good deal to you? Yes. Yes it is. Those slicks cost like 1k brand new btw, and NT01's of that thickness are like 340 or so each so yes. it was a good deal.
Old Aug 16, 2023 | 03:25 AM
travlee's Avatar
travlee
Master
no it doesnt sound like a good deal to me, why... because they dont fit. below are stock offsets, if you do get the spacer/adpater you will effectively be a +7 front and rear.. you will more than likely rub more than a prostitute giving a hand job, i ran 18x9.5 +23 front and 18x9.5+15 in the rear and it was dang near perfect that is pretty much the norm (some run 18x10.5 +15 rear) it also requires rolling the fenders in the rear for both 9.5 and 10.5. my fronts rubbed the top upper fender liner screw, so you being .70 inches out from the centerline in the front will cause issues, and .27 inches further out rear.. unless you have stupid camber gang retard settings, you will prob will not only need to roll the fenders but also pull them. not to mention to get the retarded camber, you will need parts that chik-fila wages prob wont cover
with your very limited driving experience, you dont even need to worry about racing slicks or whatever tires are making your dick hard. you should focus on not Dugan'ing the car
Performance/Touring - 18x8 - 30 offset
Track - 18x8-30 front, 18x8.5-33 rear
Old Aug 16, 2023 | 04:51 AM
e30cabrio's Avatar
e30cabrio
Look at it this way:
Would you try to nail rollerskates on your skateboard & do hardcore tricks?
It is not safe for you or anyone else on the road near you.
Please do not drive on this mess.
