Light smoke from exhaust
Old 11-26-2023, 07:28 AM
Kxv
Kxv's Avatar
Default Light smoke from exhaust
Hey all, recently i noticed after i rev the car slightly a very small amount of blueish smokes comes out (very light not alot) the car has no cats so just plain test pipes, doesn't smell like coolant nor oil burning just reg catless fumes. Ill leave a video so you guys can see it. Any help is very appreciated.
File Type: mov
Old 11-27-2023, 06:40 AM
Aeneas137
Aeneas137's Avatar
did it just start emitting the light blue smoke recently or has that been going on for a long time? have you made any changes to anything recently? Blue is concerning because that's the color of your coolant, if you're using Asian coolant.
Old 11-27-2023, 12:52 PM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,094 Likes on 775 Posts
That looks like water vapor. It's normal.
Next oil change, measure how much you drain. If you have no oil leaks, that will tell you whether your engine is consuming oil or not.
Old 12-05-2023, 09:34 PM
OrrinKunde
OrrinKunde's Avatar
Just wanted to give you a heads up that it's pretty normal to see a slight blueish tint in your exhaust if you have a catless setup. But don't worry, just keep an eye on it and make sure to monitor your oil levels.
Spoiler
NavyPat350z
03-04-2012 04:21 PM
kramykram
09-28-2008 10:44 PM
jehamilton_98
10-18-2007 08:09 AM
CarlosZ
01-02-2006 01:27 AM
MIAPLAYA
03-01-2004 07:16 PM
Quick Reply: Light smoke from exhaust
