no cel/ses light helpp
on
recently got a 2006 manual Z 136k used to be rev up, but og owner blew a hole in the block.. so a regular de (engine and harness) was swapped in and i had to finish buttoning it the harness.
so the issue is that the ecu can’t connect to the car, i got og ecu so i expected the car to start on limp mode but it won’t even be recognized.
bought a nats deleted ecu and borrow a friends.. nothing still. i tested mine in his car and it worked fine. tested the idpm box and worked fine. i’m getting power to 119-120 but no communication. to the obd2 port.
after about 2 weeks chasing this down. i’ve read a few posts where it says the pin out is the same in the ecu, but F1F2F3 (body plugs ?) and 102 (white connector) need to repined ?
someone please help..
That's a tough one since the vehicle has been modified outside of factory spec. A agree with your assessment, the interior harness pinout is most likely different. My suggestion would be to grab copies of the FSM for a standard DE equipped Z33 (04-05) and an 06 Revup. Then compare your body harness diagrams and pinouts to the ECM (ECU) and BCM. It's very possible a wrong pinout somewhere is shorting out the canbus and causing communication to the ECM to fail, but it's also possible your modified ECU is dead, or a wiring fault has damaged it.
Personally, I would get the correct engine, harness, and ECU meant for the 06 and install that. You're in a pickle with a frankensteined Z now, even if you sort this problem out, there's no telling what other issues may pop up down the road.
Note: With a little bit of online searching, you can find downloadable FSMs with all the wiring information for free.
Good Luck!
-Icer
Good Luck!
-Icer
maybe you should just get a rev up motor and drop it in instead. Like mentioned above who knows if other problems may come up even after you get it to fire up. Good luck man
erikkz
03-06-2021 12:18 PM
