No gauges working
Old May 13, 2024 | 06:41 PM
brysonmartin's Avatar
brysonmartin
Default No gauges working 03
Does any one know how to fix this. None of the gauges above the steering wheel or center gauges light up or move except the dials on the oil pressure and battery gauge. Everything works fine but nothing shows up on the dash except for seatbelt, emergency brake, etc… I originally thought it could’ve been a fuse, but I have tested all of them and taken all of them out and they are all good.
Old May 15, 2024 | 05:05 PM
brysonmartin
Any ideas?
Old Jan 7, 2025 | 07:09 PM
GaryH350z's Avatar
GaryH350z
I have the same problem. No odometer and no dash lights at night.
Old Jan 8, 2025 | 05:41 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Two questions: when did these gauge problems first start happening? Second- have either of you tried pulling the triple gauge pod and examining the connection between the main harness and the pod itself?
Old Jan 8, 2025 | 09:57 AM
GaryH350z's Avatar
GaryH350z
The left gauge at the top that shows the speed started faltering about a year ago. The display turned light orangish but I could still read the speed. Then a few weeks ago it completely went out. I took the waterfall apart to replace the head unit that had stopped working years ago. I wanted to replace it with a cd/radio. So yes the harness was apart and now back together. I don't recall exactly when the odometer stopped working at the dash lights, sometime last year. I read the threads on this and apparently disconnecting the battery for a few days can correct it, so I guess it is worth a try.
Old Jan 8, 2025 | 05:14 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Best to remove and check continuity plug-to-plug on the ribbon cable behind the waterfall. Well known deterioration/breakage issues.
Old Jan 8, 2025 | 06:44 PM
GaryH350z's Avatar
GaryH350z
I noticed that when the white box is disconnected a lot of dash stuff doesn't work. I thought that was for climate control. I do see a couple nicks in the ribbon cable. I see a lot of used ones on ebay.
Old Jan 8, 2025 | 06:52 PM
Whiskers1996's Avatar
Whiskers1996
With the white box disconnected, the gauges wil light up but pretty much useless (I think fuel/coolant may work still from memory?).. With the white box connected and ac controls disconnected, it heater circuit witll turn on full blast.
I recently bought a replacement cable, which did not work.. It turns out, from removing the white box so many times, the ribbon cable came loose on the connecter.. worth checking.
Ryan-350Z
Sep 18, 2023 12:43 AM
Tylove27
Sep 16, 2022 05:23 PM
vaske04
Jul 23, 2013 03:38 AM
EnkeiRC5
Sep 23, 2012 03:09 PM
chi-Z
Jan 21, 2008 10:13 AM
