Engine makes weird sound under 2,100 rpms
I recently bought a 2005 350z with a vq35de, and have noticed when I’m accelerating below 2,100 rpm’s it makes a weird sound, but as soon as I get to about 2,100-2,200 rpms it goes away. Only happens when in gear and accelerating, haven’t noticed it happening much in first gear, a little in second, but it happens in every gear after that, and doesn’t happen when reving in neutral, anyone have any idea of what could be the cause of this? And if I should be concerned?
well the only thing I can think of that I know about that would possibly be related to the flywheel, would be it has an after market stage 2 clutch, so maybe when putting a new clutch on they also put a light weight flywheel on but I’m not sure
Chances are they did. Only way to find out is by dropping the transmission. Or maybe you can check it out through the inspection plate on the transmission. Although its probably too hard to really see the flywheel.
I just installed a clutch kit with light weight flywheel from Z1 about a month ago and I get that chatter/rattle noise at low rpms. You'll get use to it if not you can purchase an OEM flywheel for $1,000 or Z1 has a nodular one that is very similar to oem specs that wont be noisey.
I watched some videos and it doesn’t seem like the sound from a light weight flywheel is quite right, it seems like that sound is present even at idle, and it seems like it’s more of a clacking sound, the sound I’m hearing is more of a uh humming or roaring sound that happens between 1,500 and 2,100 under acceleration only, so any other ideas on what this could possibly be?
Some lightweight flywheels will still make some noise at idle and not in gear.
When it's in neutral, does the noise go away when you depress the clutch pedal? Or does the noise change at idle if you cycle the clutch pedal?
On my car i do get noise in neutral and if i press the clutch pedal the noise goes away. This was already happening before I installed the new clutch. Only difference is the noise is louder. Just thought I shared this information
In terms of bushings/mounts, I would check engine, transmission, and differential for signs of aftermarket parts or broken units . Do you have any idea what brand "Stage 2" clutch was put in? Any details or receipts/records for that? If it's a metallic or puck style clutch, there could be noticeable NVH changes and engagement behavior changes. I strongly recommend staying away from a solid or poly transmission mount for street use, those will cause a massive increase of NVH inside the vehicle. (Note: NVH = Noise, Vibration, Harshness).
Good Luck!
-Icer
Kopala
Jul 13, 2024 05:10 AM
