Front tow reciver problems
Old Jan 8, 2026 | 07:16 PM
PaulWalker0513's Avatar
PaulWalker0513
Question Front tow reciver problems
I have a 2007 350z grand touring and I have recently noticed after having the z for about 3 years that I dint have a front receiver for a tow hook and was wondering if that is just me because ive read online that every z has one and after checking the aluminum bumper itself it doesn't even look like had ever been of there its the oem factory bumper downst look like one was even cut off and im wondering where I can find a new bumper thar has the tow hook mount and hook I have also realized there isn't a spot in the hatch for a tow hook to sit either any thoughts as to why my z i like this???
Old Jan 9, 2026 | 05:26 AM
Heel Til I Die's Avatar
Heel Til I Die
Just to be clear - you're saying that your aluminum crash bar behind your front bumper does not have this welded to it? And there is no sign that it used to be there and it has been removed?
That would be strange. There is no attachment point to the bumper itself. You have to look in the front grille to see it. They're available for purchase. Part # 62030-CD705 for 05-08.
The rear tow point is on the LH hanging down by the exhaust. This is all assuming your Z is USDM...
If you have zero two points, I guess the PO was 100% confident s/he would never need to be pulled anywhere and removed them for weight savings/because racecar.
Old Jan 9, 2026 | 07:48 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry- even Z racecars need tow hooks to comply with rules. And there's never been a tow hook attachment on USDM Z33 hatches as the OP mentions. I suspect he's not looking in the right place(s).
Old Jan 9, 2026 | 03:13 PM
PaulWalker0513
Question
Po installed an aftermarket tow hook thru the bar with a high grade bolt thru the aluminum bumper on the left side and no there is not a tow hook in the back but he said the og owner never had one as far as he knew he never used it im 3rd owner and im very confused because I think and aftermarket one would be cool to have also I know it has the tow hook cover minus the tow hook and all but he also gave me a bracket the clip on the the cover that mounts the plate ive never heard of that
Old Jan 12, 2026 | 05:05 AM
Heel Til I Die
That flappy black fabric thing is called a tow strap. They look to be mostly useless and the kewl kids throw them on there to make it look like a racecar, I guess...
Sorry D - I did not actually mean it was a racecar. I was being somewhat tongue-in-cheek and saying "because racecar" as the explanation for something useless. lol.
Old Jan 12, 2026 | 05:16 AM
PaulWalker0513
I know it does work as ive been pulled thru snow and on trailers with it just fine but would def like to have an actual tow hook
Old Jan 12, 2026 | 05:23 AM
Heel Til I Die
You should still have the threaded triangle-shaped metal piece welded in the middle of the aluminum crash bar. If not, and you really want it, get a new crash bar and install it. They're about $70 on the fleabay. Probably cheaper than having a new piece welded on.
I'm still not understanding the question about the rear. There are plenty of aftermarket ugly hooks that are available.
bbl.driZy
Jul 22, 2024 04:37 PM
tw8715
Feb 3, 2009 07:31 PM
chrs870621345
Mar 12, 2008 01:07 PM
