Rattle with clutch/flywheel unit...?
Old Apr 18, 2004 | 02:44 PM
gtbuzzbee's Avatar
gtbuzzbee
Default Rattle with clutch/flywheel unit...?
Sup guys! I have had my z for over a year and i constantly browse these forums. I have seen posts about this but i never really read into these posts. I just returned from a long trip in my Z and now i am noticing that odd rattle when i let the clutch out at idle. Even when I take off in first gear I can still hear that rattle. Can nissan fix this noise and are that aware of this problem. Thanks in advance!
Old Apr 18, 2004 | 03:17 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
well that isnt really a "problem"
the stock flywheel is a dual mass, made to absorb that sound... that sound is a softer version of what is heard when people use the lightend flywheels...
the only thing they can do to "fix" it would be to replace your clutch and flywheel...
but that is normal... it happens to some cars sooner depending on how hard the driver is on the stock clutch...
Old Apr 18, 2004 | 05:04 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
That is not a recall as in covered in the warranty. Mine is loud but I have been told it is normal. This is my 2nd manual in 12 yrs.
Old Apr 19, 2004 | 01:43 PM
03Brickyard's Avatar
03Brickyard
Yeah , mine does that too... do I have to change my clutch soon?? I have 11,000 miles.
Old Apr 19, 2004 | 02:28 PM
zul8ter's Avatar
zul8ter
I have noticed that on mine as well... But it only does it when i ingage the clutch quickly while rolling in 1st. I thought about it at first but i just assume its not a mechanical problem.....
would like to hear more info about it.
kev
Old Apr 19, 2004 | 03:01 PM
Z33Frog's Avatar
Z33Frog
Does anyone have a vid/sound clip of this noise? I'll try to make one also to see if I have to same annoying sound on take-off.
Old Apr 19, 2004 | 03:26 PM
ZRAYGO's Avatar
ZRAYGO
dam jason....can u say dejavu!!
Old Apr 19, 2004 | 04:05 PM
jimster716's Avatar
jimster716
I think it's pretty normal...I have it too. Oddly enough highend performance flywheel/clutch combos (like OS Giken) make god awful sounds just in idle with the clutch disengaged.
Old Apr 19, 2004 | 06:06 PM
MyZ4U2C's Avatar
MyZ4U2C
I had a beretta GTZ...yeah a punk car i know, but anyway i drove the crap out of that thing until 180,000 miles before i traded it and it had the clutch chatter as well. You push the clutch in, the noise goes away. My Z does the same thing. Its no big deal, doesnt hurt performance and it doesnt signify a worn clutch. Many cars do this....except Honda's.
Old Apr 20, 2004 | 09:39 AM
zturtle's Avatar
zturtle
gtbuzzbee:
That rattle could very well be a known fault. If it happens when you hit the clutch after a hard acceleration and you are coasting, it is the shafts rattling against the cuffs. You will get a new tranny and clutch pedal.
If you leave it long enough, 3rd and 6th will start scuffing.
Did you buy the car new?
This is a problem with a bulletin out - I fixed mine and put in the NISMO clutch plate, cover and flywheel at the same time.
Go to your dealership get your new tranny.
Old Apr 20, 2004 | 10:02 AM
MRfire's Avatar
MRfire
Originally posted by zturtle
gtbuzzbee:
I think the sound he has is when the clutch is OUT at idle. I have the same noise and it's magnified when I'm parked in my garage. You can also really hear it when you're at the drive through. To me it sounds like crap, but dealer told me it was normal as well.
Old Apr 20, 2004 | 10:13 AM
zturtle's Avatar
zturtle
Nope. it is not normal on '03's. There is a bulletin on certain '03s regarding this.
The main problem came from too much plastic in the clutch pedal linkage.
Old Apr 20, 2004 | 10:20 AM
MRfire's Avatar
MRfire
You don't by chance have a link to the bulletin
Old Apr 20, 2004 | 10:25 AM
zturtle's Avatar
zturtle
I am off today, but I might swing by the shop and get it. At the latest by tommorow.
P.S.
The repair comes with a new clutch pedal - so if you have the drilled covers, make sure the dealer orders a new one. If the service manager is any good, he will swap the old ones to the new pedal and STILL charge it to warranty. They are screwed on audits if they do it, but a lot take the chance.
Old Apr 22, 2004 | 09:25 AM
MRfire's Avatar
MRfire
P.S.
Any luck yet?? I'd love to check this out as mine is LOUD
Old Apr 22, 2004 | 09:41 AM
Sly_Z's Avatar
Sly_Z
sup! It's normal, my car make the same sound sometimes.
Old Apr 22, 2004 | 09:59 AM
03Brickyard
It usually happens when i start the car...
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Lee3Z
Nov 1, 2002 01:39 PM
PrototypeStan
Oct 25, 2002 06:00 PM
