Question for those who got the Bose fix
Old May 7, 2004 | 05:08 PM
vice86's Avatar
vice86
Default Question for those who got the Bose fix
I got the BOse fix on my car for the lousy automatic volume adjustment....since I got it back there is virtually NO bass in my Z now.....anyone else have the same problem since the fix? I'm about to call the Nissan dealer and complain about it.
Old May 8, 2004 | 07:57 AM
irishfan's Avatar
irishfan
There were two fixes released. The first really killed the Bass as you describe, the second was definitely an inprovement, but still not a "premium sound". It almost sounds like maybe you got the first fix and not the second - they were both amp replacements, but not the same amp.
Old May 8, 2004 | 08:00 AM
irishfan's Avatar
irishfan
More info - the first TSB was NTB02-111A, the second replacement was a "campaign", number P3140.
Old May 8, 2004 | 09:22 AM
zh.guitar's Avatar
zh.guitar
Leave your mark!
IMO...If you already notice that the Bose system doesn't "sound right" , your done. Nothing that Nissan will do will fix it. If you are used to a premium system then tear it out and start new. If you just want good sound you may be able to swap out the speakers, add a new sub, amp etc.....
Don't waste your time with Nissan on the stereo.
Old May 8, 2004 | 02:33 PM
qirex's Avatar
qirex
the last fix worked well for me.
Thumpin and tight bass (to me).
The 1st DEF killed the bass.
Do a search, this was the HOTTEST topic (besdes greddy TT) last year for us 2003 guys.
Seems the new 04' owners are pretty satisfied.
Old May 8, 2004 | 08:23 PM
vice86's Avatar
vice86
Thanks guys...that must be the problem...bass sucks right now...hopefully the second fix will do the job. I ain't looking for crazy bass, just enough to sound good.
Old May 8, 2004 | 08:33 PM
SHO-TIME's Avatar
SHO-TIME
yup... that happened to me as well with the first replacement amp. They reduced the amp power, I think. The 2nd replacement amp was definately better than the 1st but still not completely satisified. My 2000 Acura TL BOSE sounded so much better than the ones in my Z.
Old May 9, 2004 | 06:15 AM
vice86's Avatar
vice86
so then just to clarify so I know what i'm talking about when I complain to the moron manager at the Nissan dealer again....second replacement was a "campaign", number P3140 to replace the amp from the first TSB that reduced the amp power....correct?
Old May 9, 2004 | 04:40 PM
MannishBoy's Avatar
MannishBoy
The second fix definitely turned down the bass a bit, and made the thing overly bright on CDs. I used to pre-fix set my bass and treble neutral most of the time. Now, I generally use +2 bass and -2 treble (CDs) or 0 treble (radio).
The Bose still isn't all that great, but it is significantly better. It no longer is audiably tiring to me like it used to be when it sounded like the tweeters were out of phase in my car. I just wished they hadn't made it quite so bright, and made it more realistic.
Old May 9, 2004 | 09:36 PM
s9am_me's Avatar
s9am_me
so would you guys recommend the 2nd fix??(to those who did it) i agree the first fix killed the bass.
Old May 10, 2004 | 05:48 PM
BRONXWARRIOR's Avatar
BRONXWARRIOR
id recomend the second.
however the second was a voluntery recall or some ********.
so if you dont mention to your dealer there unlikely to bring it up.
bottom line is when all is said and done you still have an ok stock radio
Old May 11, 2004 | 12:50 AM
Mr_Q's Avatar
Mr_Q
I am sure mine is not fixed even though Nissan USA said my car didn't need it. (based on VIN)
I have to crank the bass and treble to +5 each to get anything. And even then the system sounds kind of flat and the bass vanishes once I get rolling on the highway.
I just don't want to add the extra weight from an aftermarket sound system. My last system weighed in at 75lbs total!!! ACK!
So for now I use my iPod with the EQ set to "rock". This overdrives the Bose auto-adjustment crap and gives me some slightly thumping bass and decent highs. Enough that I am satisfied.
Maybe if I buy a second convertible Z for crusing I'll slap a system in it....hmmm.....second Z...
Rev_Night
Nov 7, 2020 06:00 PM
issyz
Jul 2, 2017 03:04 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
