Problem with my 350z, HELP!
While i drive, the check oil light comes on for a couple seconds. It happends randomly and its only on for a couple of seconds. Has this happened to anyone else? What may be the problems?
Thanks.
Thanks.
I had my last oil change less than a month and and put on less than 1000 miles since. Anyways, i just checked my oil and i didnt have any oil! I checked under the car and there is an oil leak! Has this happened to anyone? Why is this happening.
Originally posted by Reggi914
question: When you turn on the engine and it idles, whats the oil psi? (middle gauge on the tri-pod)
Edit: When the car just starts and not warmed up, it's at 90 psi and drops to 60 psi (1/2 way) when the rpms fall to 1,000. When the rpms are at 600-750, it's at 30 psi.
Im not driving the car anymore. I had the oil change done at a local shop. It isnt just another garbage shop, its a high end shop that does high end cars. I made an appointment with my nissan dealer for teusday. I am going to take the car to the shop tomorrow to ask them to check the leak to see if they can see why its leaking.
i hope you dont blow your engine
Thanks.
Thanks.
Originally posted by JonsilvZ
Oh no! You didnt get it done from the dealer? The washer must be replaced every oil change. They probably didnt know.
Where did you hear that from? I have never replaced my washer and I haven't leaked a drop.
Do you do your own oil changes? (you probably only did one oil change because your car has just over 3000 miles in one year!)
BTW, those washers at the delaer are not cheap either!
Also, you seem like a total azzhole. Its almost as if you want my engine to blow. I guess some people are just born azzholes.
