Regular gas?
Old Jun 27, 2004 | 08:32 AM
oscarmayer00's Avatar
oscarmayer00
The Facts...
Here is the Car and Driver article read it for yourself, you'll just lose performance at the top end. Look at the test results, 0 to 60 is about the same. So if you don't race regular fuel is fine and it won't hurt your Z.
"Relying on knock sensors, the engine controller can keep each cylinder's spark timing advanced right to the hairy edge of knock, providing peak efficiency on any fuel and preventing the damage that knock can do to an engine. "
"Cheapskates burning regular in cars designed to run on premium fuel can expect to trim performance by about the same percent they save at the pump. If the car is sufficiently new and sophisticated, it may not suffer any ill effects, but all such skinflints should be ready to switch back to premium at the first sign of knock or other drivability woes. "
Regular or Premium?
Is premium fuel worth the premium price? Can you hurt a high-octane car by running it on the cheaper stuff?
BY FRANK MARKUS
November 2001
http://www.caranddriver.com/article....&page_number=1
Old Jun 27, 2004 | 03:50 PM
RJW0501's Avatar
RJW0501
Originally posted by zzz350
Come on you bought a Z, put the right fuel in it. If you don't care about performance buy a Corolla, sheesh!
agree! if you have to save .30 per gallon, maybe the Z is a little over your budget.....Toyota has a 500.00 rebate on the corolla....and it burns regular unleaded.
Old Jun 27, 2004 | 05:26 PM
marhot's Avatar
marhot
Originally posted by steig
you can get unleaded 98 octane at drag racing tracks or gas stations near one. Also Ohio has an emissions check required for registration, I would think that using less than 91 octane would lead to some gas not combusting and failing an e-check if you had regular in your tank.
You can also boost your octane by using Toluene. (check out the details here https://my350z.com/forum/showthread....threadid=77978)
This was an interesting thread:
Old Jun 27, 2004 | 06:13 PM
zzz350's Avatar
zzz350
I've seen the inside of engines that were designed for 91 oct. and have consistently run on lower grade fuels, most recently a 2000 Maxima. There is major build up of crap that is left unburned and in time will definitely catch up with the cheapskate. Like the old fram commercial said, "You can pay me now or pay me later".
For me I want the performance and I would choose to pay the piper with every fill-up rather that later giving it to the mechanic.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
