Tach bounce?????
Old Jul 2, 2004 | 08:30 AM
TTSupra's Avatar
TTSupra
Question Tach bounce?????
I have been searching on this for the past 2 days and cant find anything.
When I accelerate the tach needle bounces for a second then starts to climb.
Is this a normal thing in these cars??
Also one question off this topic.
I hear a clicking noise when I hit the brakes like when moving slow when about to pull in my drive way. It is deff coming from the brakes cause its only when I hit the brakes.
I think this might be normal pad movement but im just wondering if it might be something else that is a known problem.
Thank you
Old Jul 2, 2004 | 09:55 AM
MadMax76's Avatar
MadMax76
I have a guess in case you have a 6 speed MT. I am guessing that either you don't let the clutch out far enough so it slips and the needle bounces until you fully release the clutch so it loads the engine and the revs come down a bit. The other guess would be that your clutch is not working as it supposed to. These are just guesses and I might be completely wrong but nothing else comes to my mind.
Old Jul 2, 2004 | 11:01 AM
TTSupra's Avatar
TTSupra
Its not when im letting the clutch out its when ever you give gas the needle will bounce a little bit and it does not matter if you are getting on it or even giving a little gas bogging it it will bounce a little bit.
Its not the clutch the clutch is not slipping and happens like I said with or without a heavy load.
Old Jul 2, 2004 | 04:01 PM
raidersfan's Avatar
raidersfan
Mine does it to. if you punch it while driving it bounces then climbs. mine has done it for 35k miles now.
Old Jul 2, 2004 | 07:26 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
is that only when VDC is on?
Old Jul 5, 2004 | 05:18 PM
TTSupra's Avatar
TTSupra
Cool guess its normal thanks for the info.
I do not drive with the vdc on.
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
Killermove
Jun 14, 2011 07:38 PM
350ondubZ
May 12, 2003 09:16 AM
someone
Nov 19, 2002 08:38 PM
