2004.5 ECU Reset Procedure?
Old Jul 15, 2004 | 01:55 AM
AceJ587's Avatar
AceJ587
Question 2004.5 ECU Reset Procedure?
I believe it's been changed since the 04's and earlier. TS's procedure doesnt work. Anyone care to enlighten me? Otherwise I guess I'll do it the old fashioned way (disconnecting the neg on the battery)......thanks
-Jackson
Old Jul 15, 2004 | 11:27 AM
eazy's Avatar
eazy
No it hasn't. It works. I've done it twice. In the TS directions it states that the timing is critical. They weren't lying. Try again.
Old Jul 15, 2004 | 12:05 PM
350zSpeedRacer's Avatar
350zSpeedRacer
Timing is VERY critical. It may take a few tries, but you'll get it.
Old Jul 15, 2004 | 12:22 PM
AceJ587's Avatar
AceJ587
I must be retarded, I tried it like 10 times! maybe I need to read the directions again lol. thanks guys
-Jackson
Old Jul 15, 2004 | 12:58 PM
AceJ587's Avatar
AceJ587
It worked!!!!! I dont have a stop watch though, it was a pain in the azz lol, doing all that and trying to count simultaneously lol.
Old Jul 15, 2004 | 11:46 PM
RedX's Avatar
RedX
how do you reset it?
Old Jul 16, 2004 | 12:00 AM
AceJ587's Avatar
AceJ587
http://www.technosquareinc.com/350reset.htm
Old Jul 16, 2004 | 01:12 AM
sentry65's Avatar
sentry65
the burninator
just curious, what's wrong with disconnecting the negative from the battery?
Old Jul 16, 2004 | 02:07 AM
AceJ587's Avatar
AceJ587
This procedure just resets the ECU, without erasing the memory on your stereo and Gawd knows what else.
Old Jul 16, 2004 | 04:43 PM
Nforce1's Avatar
Nforce1
Im curious... What does ^^^ all that do?!
Old Jul 16, 2004 | 05:56 PM
kcobean's Avatar
kcobean
The ECU stores certain data in memory regarding performance variables, Error codes, etc. When you either perform the ECU reset using the gas pedal sequence or disconnect the negative lead on the battery for 24-ish hours, you cause the ECU to forget that data and start with a clean slate. This may be needed after certain mods so that the ECU isn't controlling the engine using stored variables that don't really match the actual inputs that the engine is seeing.
Old Jul 16, 2004 | 11:33 PM
AceJ587's Avatar
AceJ587
Originally posted by mc350z
ive done this a few times too
after you hold the pedal in for 10 sec it starts to blink. ok i usually wait 10 sec and it blinks fast then i hold it down for 10 more seconds. but it still blinks am i doinf it right thats the only part of the instructions i dont get
Youre doing it right, as long as the CEL doesnt come back on when you start the car again, youre fine. It's sypposed to keep blinking up until the end of the procedure to when you shut it off.
hulkout
Tuning
Sep 30, 2015 12:33 PM
Darkspy
Sep 7, 2015 09:09 PM
