Bose amp replacement
Old Oct 15, 2002 | 06:26 AM
Aldous's Avatar
Aldous
Default Bose amp replacement
can you guys give me more info on this replacement amp for my Bose system... that way i can relay the info to my dealership so i can improve the sound of the car... is this a recall or a straight order replacement that i will have to pay for myself? any info would be great....thank you
Old Oct 15, 2002 | 06:33 AM
N74DV's Avatar
N74DV
chances are your delaer will not knwo of the fix. I called mine yesterday to inquire. The service advisor is checking into it and is supposed to call me back today. when I find out something I'll be glad to post it.
DJV
Old Oct 15, 2002 | 09:08 AM
N74DV's Avatar
N74DV
just got off the phone with my Nissan service guy. He says Nissan is working with Bose to find the cause and fix for the problem.
He says nothing he can do now because the fix is not avaiable.
I thought some folks on this list had the amp replaced and it cured the problem??
How about part numbers for the replacement amp??
DJ
Old Oct 28, 2002 | 01:30 PM
ares's Avatar
ares
Veteran
so nissan knows of the problem and is working towards a solution. good enough for me. be sure to relay any new info on this matter, as I want to be sure to stay on top of this.
Old Oct 28, 2002 | 04:37 PM
Edretti's Avatar
Edretti
I can't seem to find the original complaint to the Bose system on this thread. Is it the volume going up and down which drives me nuts???
Edretti
Old Oct 28, 2002 | 04:40 PM
vicmar90's Avatar
vicmar90
Yes.
ares's Avatar
ares
Veteran
thats my problem also the base kicks in and does some wierd stuff too. it seems it feeds back its own noise into the ambient sound sensor, and raises its own volume to overwhelm itself. it then resets when theres a break in the music.
it gets rather annoying.
Old Oct 28, 2002 | 04:57 PM
N74DV's Avatar
N74DV
Nissan will be releasing a bulletin to dealers in November. Don;t know when in Nov. but sometime.....
As soon as the bulletin is released to them you can call your dealer for an appointment. Supposed to be a simple amp swap. Should take no longer than an hour once they get to it.
Call your dealers beginning Nov. 1 and bug the sh#t out of them until they get the bulletin.
DJ
Old Oct 28, 2002 | 05:02 PM
captj3's Avatar
captj3
Question bose amp
nna interveiwed me last week, they said the new amps should be available the second week of november.
good luck
Old Oct 28, 2002 | 06:28 PM
Zya's Avatar
Zya
Charter Member #72
Default I heard it's the microphne
I spoke to my sales rep today who had just returned from tech training on the Z this morning. The trainer from NNA specificaly mentioned the Bose problem. He told the trainees that Nissan got a bad batch of mics and the problem had already been fixed in production. A service bulletin will be coming out to fix the cars with the bad mics.
Old Oct 28, 2002 | 06:31 PM
SunsetZ's Avatar
SunsetZ
So now it is not just the amps but the mics as well? Maybe that takes care of both problems, auto volume and muddy bass.
Old Oct 28, 2002 | 06:35 PM
pointfivezero's Avatar
pointfivezero
Charter Member #16
When I spoke with Nissan last Friday, they said to go ahead and make an appointment at the dealership (the 2nd week of November, to be safe.) They will be issuing a TSB this week. My dealership was also not aware of this issue.
As far as I know, this is NOT a blanket fix. You need to start a case with Nissan (1-800-NISSAN1) to insure replacement.
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
