is it normal?
Old Aug 15, 2004 | 09:14 AM
hungster's Avatar
hungster
Default is it normal?
After driving it hard down some mountain runs, the car is really hot. Is it normal for it to have so much heat soak?? I mean its so hot that there is a little bit of smoke coming out of the engine bay. It smells like a little bit of plastic burning. Nothing major, but yea even at night when i run it hard it has bits of smoke coming out. I drive it really hard though, bouncing off the rev limiter for a second before a hard turn, driving it that hard. But is it normal for our cars to heat up so much? is this a big reliability concern on the Z?
Old Aug 15, 2004 | 09:34 AM
The Brickyard Rat's Avatar
The Brickyard Rat
How long have you had it. Many of us smelled something like plastic burning in the first couple of weeks then it went away. I don't recall seeing smoke though. A trip to the dealer might be in order.
Old Aug 15, 2004 | 11:02 AM
hungster's Avatar
hungster
ive only had the car for a little over a month, but i have 3000 miles on it
Old Aug 15, 2004 | 11:10 AM
Nforce1's Avatar
Nforce1
Ive had my car for... 2 1/2 months, just reached 3500 miles last night.... Ive never smelled burnt plastic, let alone have it smoke a little. But then again, I dont drive it nearly that hard....
Old Aug 15, 2004 | 11:30 AM
hungster's Avatar
hungster
it only happens after a long hard run, the run last about maybe 15-20 minutes, but its hard running toppin in 3rd gear at most, and than a quick rev match and downshift with hard braking into second for the next turn. I have a really twistie back road that most people only drive at about 25-35mph, and on 2 hairpin turns they take it at 10mph. But at night where there is no traffic you can take it hard at a slight drift uphill. So yea it only happens after driving the car very hard.
Old Aug 16, 2004 | 09:20 AM
Jetpilot718's Avatar
Jetpilot718
Hmm... maybe look into an oil cooler kit? Im thinkin about it also... maybe for next oil change.
Old Aug 16, 2004 | 11:05 AM
hungster's Avatar
hungster
yea im thinking that too, oil cooler from motec, and a nismo thermostat should help out alot.
Old Aug 17, 2004 | 05:11 PM
hungster's Avatar
hungster
anyone else with insight or problems on this, i still havent gotten any real answers and i really dont want to take it into my dealership and say "well when you drive the crap out of it smoke comes out..." lol
Old Aug 17, 2004 | 05:31 PM
Darren's Avatar
Darren
It's not uncommon for the brakes to smoke a little if you run them really hard. Do you have the stock binders? Also, if you're really whipping the engine, any fluid that seeps out will burn off. The more that you beat on your car, the more likely it is that gaskets, seals, and fasteners will loosen up, thus promoting more fluid leakage.
Old Aug 17, 2004 | 05:35 PM
Darren's Avatar
Darren
As for the oil cooler, great idea! I put a BIG remote filter on mine, the same size used on the Chevy V8's, and a 6 pass cooler with fan. You will be amazed at what it does for your oil. I use Mobil 1 0-30 and the bigger filter and lower temp keeps it nice and clean. I drained a bit after about 2500K and it was still a nice clear honey color.
Old Aug 17, 2004 | 06:01 PM
ares's Avatar
ares
Veteran
Id say thats not right at all. hopefully the engine temp doesnt get high?
check all fluids would be my first stop
Old Aug 17, 2004 | 06:32 PM
hungster's Avatar
hungster
yea i check all the fluids, it seems fine a little high but thats because its really hot. the motor temp isnt over heating at all, well atleast thats what it says on the temp gauge. So yea i was just kinda confused. Maybe its the brakes but it had smoke coming out of the bay and sides of the wheel wells for atleast 5-10 min but i was on the brakes hard in these hairpins, i guess i will have to do it during the daytime and really inspect it. Well hopefully if anything does break my service departement is as good as they kept saying when they sold me my car. but only time will tell....
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
