Problem with my rear windshield wiper?
Old Aug 15, 2004 | 07:48 PM
guru_ck's Avatar
guru_ck
Default Problem with my rear windshield wiper?
You know how you can flip up your front windshield wipers when you are washing your car? Is the rear one supposed to do the same thing because it won't let me lift it up at all. At the most maybe half an inch. Thanks!
Old Aug 15, 2004 | 08:49 PM
dkny_boi's Avatar
dkny_boi
Mine doesn't flip up either. I don't think you can flip it all the way up.
Old Aug 15, 2004 | 08:50 PM
guru_ck's Avatar
guru_ck
Ok cool, I thought it was just me.
Old Aug 16, 2004 | 11:24 AM
eazy's Avatar
eazy
Yeah, the back one doesn't flip up.
Old Aug 16, 2004 | 07:27 PM
Jetpilot718's Avatar
Jetpilot718
Yeah, WTF, why not?
I noticed this also...
Old Feb 17, 2005 | 09:09 AM
boma's Avatar
boma
I'm sure the reason it doesn't flip up is so the wind won't make it pop straight up in the air when driving at high speeds.
Old Feb 17, 2005 | 09:30 AM
lunartick13's Avatar
lunartick13
I don`t have a problem with mine, I took my off.
Don`t like it, don`t use it....
Rear wiper motor went too, lost like 15 lbs...
Old Feb 17, 2005 | 09:38 AM
MovingViolation's Avatar
MovingViolation
^ I'd like to do that to. Was it a difficult process?
Old Feb 17, 2005 | 06:12 PM
lunartick13
Not at all, I used a battery post puller for the wiper arm, it fit just right and it came off fairly easy. You have to pop the cover for the rear hatch to get to the motor and the whole assembly comes right out but then you are left with a hole, where the motor shaft was.I was able to machine a piece of delrin (dull black plastic) to cover the hole. I believe someone did a thread on this a while back where you can go to Home depot and pick up all the items you need. you may want to do a search on that. Good Luck!!!
Old Feb 17, 2005 | 06:55 PM
corsair's Avatar
corsair
I also removed the rear wiper. Rain pretty much sheets off the car while driving anyway, not to mention that it doesn't rain much here. Car looks much better. I think the wiper assembly is closer to 5 lbs. though. While your back there, don't forget to remove the trunk weight.
Old Feb 17, 2005 | 11:12 PM
boma's Avatar
boma
Boo. I love my rear windshield wiper. I wish all coupes with a trunk had one.
Old Feb 18, 2005 | 03:16 PM
SunsetZ33's Avatar
SunsetZ33
Trunk Weight??
I'll remove that too.
Where is it and how much weight can I save by removing it?
No point in keeping unnecessary weight.
Old Feb 18, 2005 | 05:01 PM
boma's Avatar
boma
Under the Black plastic panel when you open the hatch. (its on the hatch).
You will then see the weight. Unscrew it, and you'll save about 3-4lbs.
Old Feb 19, 2005 | 08:07 AM
SunsetZ33's Avatar
SunsetZ33
Cool, Thanks!
Uriyo_
Sep 8, 2021 08:46 AM
