Harness Belt Install Question
Old Aug 20, 2004 | 02:35 AM
GAR350's Avatar
GAR350
Default Harness Belt Install Question
HMS has recommended that I install the inside lap belt under the existing OEM female connection point. As this is mounted to the seat frame it appears difficult to get to. I have reviewed the related threads and see that many have suggested that this is a bad idea. However, should I go this way, what is involved to remove the seat to get at this bolt?
Old Aug 20, 2004 | 05:06 AM
Audito350Z's Avatar
Audito350Z
there are 4 bolts holding the seat to the floor of your car... one at each corner... remove those
then, unplug the connectors under the seat and pull the harness loose from the seat frame
take the seat out
or... you can skip the undo-the-harness part and just tilt the seat over on it's side so you can get to the plastic cover that is covering the seatblet anchor. There's one screw and two (maybe three) clips that hold on the cover. Remove the cover and you will have access to the bolt holding the anchor in place.
Cheers,
PeteH
Old Aug 20, 2004 | 07:24 AM
mofoz's Avatar
mofoz
i heard that you arent supposed to mount the belts to the seat, you are supposed to moun them to the car itself, that way if the bolts on the seat give, your harnesses dont give automatically. The guy i talked to told me that i should install Eye bolts and connect the lap and sub belts from there.
m_0g
Jun 3, 2021 10:05 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Vigman
Nov 17, 2015 04:34 AM
