Oil Change...
Old Aug 28, 2004 | 03:51 PM
pooter's Avatar
pooter
Question Oil Change...
Hello,
I'm happy to say that I just bought an '04 white Z about a month ago. I will be reaching the 3000 mile mark in a bit here and would rather change the oil myself. I was curious if there was any special procedure to changing the oil or is it just like any other car?
One thing specifically that I'm wondering... Is there anything I need to do to make the computer realize that I've changed the oil or is that even necessary? The reason I ask is cause I know some cars have an 'oil change' light that comes up every so often. I wasn't sure if the Z's had that or if they just leave it up to the owner to do know.
I tried using the search feature but couldn't find anything specific about this so I'd appreciate it if I didn't get yelled for not searching.
Thanks, ahead of time.
Larry
Old Aug 28, 2004 | 03:58 PM
kcobean's Avatar
kcobean
No such 'bogus intelligence' in the Z. Just change it and go on your way!
Old Aug 28, 2004 | 03:59 PM
pooter's Avatar
pooter
Excellent.... Thanks man.
I appreciate it.
Larry
Old Aug 28, 2004 | 04:16 PM
jeffie7's Avatar
jeffie7
Well.... I really dislike changing the Zs oil.
I like how the drain plug is right next to the oil filter so you can remove both and have the oil drain down into the same pan however Nissan made it so you could get to the drain plug but NOT get to the oilfilter unless you remove the underbody covering....
Now this is where the I hate chaing my 350Zs oil part comes in.
there's about 12-16 bolts you have to remove in order to drop underbody covering down and then if you hvae the area package the front piece tends to also come off when you remove it =`(
ONCE that underbody cover is removed the Z is a very easy car to change the oil in - checking the dipstick when you're done that's still a total PITA
oh and when you're done have fun putting BACK the 12-16bolts
BAH
Why couldnt nissan make it so there's a big enough hole for the oilfilter? they made it so you could drain the oil with out having the cover off but noooooo they couldnt do the same for the filter =`(
bah
BTW I changed my 350Z oil last light I put my tripmeter to setting B and reset it then when that gets to 2500 I buy a filter and oil so right when I turn 3K I can change it
P.S
Keep track of all receipt so if something happens under warrenty you can back up that you did in fact change the oil on time.
Old Aug 28, 2004 | 04:23 PM
liljerk's Avatar
liljerk
get a drill w/ a socket attachment and you can take off the underbody cover in less than 2 minutes
Old Aug 29, 2004 | 12:33 AM
yobri's Avatar
yobri
Basically, it's easy for those that have a lift handy as you can rig the filter change to be fairly painless and minimally messy with the underbody cover on... but then again, I believe that probably less than 5% of us on the board have accessibility to such a luxury...
Old Aug 29, 2004 | 01:34 AM
zand02max's Avatar
zand02max
Default Re: Oil Change...
Originally posted by pooter
Hello,
Larry
No oil light.
The only extra thing you need to do is take off about 10-15 10MM (I believe) bolts and remove the plastic cover. That lets you get to the oil filter rather easily.
GL. Ensure you keep your receipts for warranty reasons.
Old Aug 29, 2004 | 06:25 PM
DAYTONA-ZED's Avatar
DAYTONA-ZED
Hello,
Larry
I just changed mine this afternoon for the first time. It took 2 1/2 hrs due to the fact i had to make a trip to ADVANCED AUTO for a smaller cap to put on the filter to screw it off. Also another wait for the typical afternoon summer rain storm to pass. Have used these metal caps in the past and have never crushed an oil filter. They use a 3/8ths drive ratchet inserted in the top of the cap to give you a lever to turn off the filter.
Taking off the bazillion bolt/screws was not that bad as i used an electric screwdriver with a phillips bit to put them back in. Be careful that the retainer clips in the screw holes are lined up or you will risk cross threading the bolts.
The actual oil and filter change was very easy. One thing i learned from this board is to rotate the cover out of the way instead of pulling out the retainer button and taking it off. Just be careful not to bend the sheet metal plates inside the cover as you turn it out of the way as they can get caught . if you do bend one it can be easily bent back into its proper position.
I used RHINO RAMPS ( the pair rated for 12000 lbs) and rear wheel chocks. Will probably get jack stands in the near future for extra safety.
Hope this helps.
Old Aug 29, 2004 | 07:33 PM
pooter's Avatar
pooter
I appreciate all your info.
Looking forward to removing those covers....riiiiiggghhhttt.
Thanks again
Larry
Old Aug 29, 2004 | 08:45 PM
jeffie7's Avatar
jeffie7
If you're anything like me you also want to use a torque wrench on the filter/drain plug 95% of the people don't use them but I like to due to having problems with older cars and people over torquing the plug!
14FTLBs it good for the filter and 25FTLBs for the drainplug
Old Aug 30, 2004 | 04:32 AM
lowrider's Avatar
lowrider
I only remove the two rear screws when I change my oil. The aero cover then drops down far enough so I can fit my arm and filter wrench through the space opened up by the lowered cover. It's a PITA, but easier than removing the whole cover. BTW, I use a K&N filter with the nut fitting at the end,
Lou
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
