Grinding Second Gear
Old Sep 6, 2004 | 05:37 AM
guestwea's Avatar
guestwea
Default Grinding Second Gear
I have an '03 Enthusiast with 15,500 miles. When you take it to 5 grand and above in first gear, you get a horrible grind when trying to go to second. Under 5000 it shifts smoothly. Have not taken it to the dealer yet, so I would like to know what to expect. The last time I had it in, they said the release bearing souned like it was bad and hinted that the car might have been abused. I have not noticed any noise that would indicate a bad release bearing myself. I told them it WAS a sports car and not a Lincoln Town Car, and yes it has been driven like a sports car, (and even that is on rare occassions) but NOT abused. Any idea what kind of crap I can expect when I take it in for these problems?
Thanks
Old Sep 6, 2004 | 08:17 AM
Jetpilot718's Avatar
Jetpilot718
Sometimes, if the fluid isn't warmed up, it is a tough shift from 1st to 2nd. However, check your technique before shifting - make sure you are fully depressing the clutch before shifting.
Old Sep 6, 2004 | 09:30 AM
VeeTec's Avatar
VeeTec
You could have a bad second gear synchro, which should be covered under warranty.
Old Sep 6, 2004 | 12:45 PM
pyroteknix's Avatar
pyroteknix
My 'bad 6th gear synchro' turned out to require a replacement clutch and me to pay the 'diagnostics' of removing and stripping my gearbox.
I had the same symptoms, just with 6th.
If I let the revs drop to idle, press the clutch, slip it gently into gear, blip the throttle and release the clutch, it worked....just. If I just tried to shift from 5th through to 6th...it just made horrible grinding noises.
Old Sep 7, 2004 | 09:15 AM
Mukrat's Avatar
Mukrat
Race Naked FTW!
3000 miles when I took mine in for Second Gear grinding. Turned out to be synchros and they replased the entire tranny.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
