how are the tire pressure sensors powered?
on
Re: how are the tire pressure sensors powered?
Originally posted by jasonintoronto
is it a battery? kinetic?
Actually, now that I think about it, Im pretty sure it is kinetic. Think about it, the TPS doesnt work until your wheels are MOVING. If they were self powered, this would not be an issue. Also, how retarded would it be to have to remove the tire to change a battery in the TPS module? heh
on
Originally posted by Jason@Performance
good question... :-/
Actually, I doubt it would be kinetic. It's probably as Kolia stated - it uses a magnetic field. The reason that you must be moving for them to work is because the sensors in the wheel must move through the field generate by the fixed transducers near each of the four wheels.
Basic electromagnetism at work here. If you move a coil through a magnetic field you can generate a current. You have to get the wheels spinning so the coil in the sensor passes thru the magnetic field often enough to generate enough power to run the sensor.
Well, according to the service manual (which doesn't come right out and give you the answer), there is no battery in the sending units, and there is no emitter in or near the wheel wells. Therefore, it would make sense that they have to be kinetically powered, much like a 'self-winding watch'. The confusing part is that self-winding watches require movement in two directions (like swinging arms while walking). Once a wheel is spinning, what "reciprocating motion" is there to generate power? The other thing that is confusing is that there is a "transmitter activation tool" that can be used to power up the transmitters without driving the car for the purposes of transmitter identification/learning. That would make me believe that these are RFID devices that are powered by an external source as Kolia suggested, but that source is a mystery even after reviewing the service manual
Also interesting to note is that the identification process for which sensor is in which wheel can be accomplished by placing the computer into a learning mode and then setting the tires to specific, varying pressures at each corner (3 pounds difference per wheel) and then driving the car. When the sensors generate their readings for the varying pressure, the computer knows that "x" pounds is LF, x+3 is RF, x+6 is LR and x+9 is RR. Pretty sneaky way of getting it done.
on
LOL. What if all our TPS were just Nissan BULL! LOL.
That was a funny thought, and I'm sure they couldn't BS something as big as that without someone ripping them apart for it.
on
My guess is that it is passive (i.e. not converting the RF wave to electricity).
Michael.
Actually, we're all wrong. They're battery powered.
See section WT-19 of the 2004 service manual. There are references there to diagnostic codes that indicate low battery in each of the 4 transmitters in the TPS units.
There is also a section there on the Transmitter Activation Tool which allows a tech to activate the TPS sensor in the shop - no wheel rotation. Therefore it's not kinetic or induction based.
on
bad TPM = warning light?
Does anyone know for a fact that, if a TPM on one wheel goes out, the warning light on the dash will light up? I had a TPM on the right front either go out (or it was damaged by the dealer during tire changeout), and on trips of over about 30 minutes the light will come on. There is no pressure problem; all tires will go from about 35 psi to about 39 psi and the light just comes on. It stays on until you stop for gas and then 30 - 35 minutes later it comes back on.
Is the failed TPM the problem?
tia,
WayneTN
tia,
WayneTN
Re: bad TPM = warning light?
tia,
WayneTN
tia,
WayneTN
The dealer would use the CAN port to diagnose this, and it should be covered under warranty, yes?
on
When the wheel rotates 360 degrees it does change direction when it reaches the bottom and then again when it reaches the top.
Originally posted by Florida350zrt
If you think about it, at one point the valve is at top Dead Center, so to speak.
I'll agree with you that the sensor is changing directions though, as many times per second as you care to measure. It is, after all, a circle.
Hey, that gives me an idea....What if I were to make an engine with "pistons" that spun around in a circular type motion. They could achieve much higher RPMs! I'll call it "The Rotary"....Nah, people would think I'm a ****(el) for suggesting such a thing.
God I hate math.
I am amused
Interesting to read the replies so far to this question, as I have previously posted on this forum as to how TPS's work, having previously contacted the UK company that makes the TPS for Nissan. The TPS is powered by an integral lithiuum battery that is permanently potted into the plastic housing along with the sensor. To preserve battery life, you have to rotate the wheel fast enough to activate an integral switch to switch the battery "on". The Nissan dealer device (probably magnetic) activates the TPS battery switch to on with the wheel/tire static. Per the manufacturer, the battery has "an average expected life under normal use, of approximately seven years." When signal is lost on a TPS, whether due to damage or battery failure, the indicator light on the dash will light up after a single BEEP as opposed to the repeated BEEP warning of a low tire.
Hope this accurate information helps!
on
Damnit MikeQ, you can be really cruel sometimes. Well... at least I was close...
Ugh. Battery powered? Are the batteries at least replaceable or do we have to spend $250/ea to replace?
Michael.
Michael.
