Shift 1, 3, 5 ??
Old Sep 13, 2004 | 07:09 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Originally posted by ingenue007
IIRC older Corvettes or Camaros had this 'feature.' It is to increase fuel efficiency.
Actually, it became a feature on the C5s and the LS1 F bodies. It was a real PITA, so tons of people bought a skip shift eliminator, which ended up being a 3 dollar fuse to bypass the whole thing (I had one on my SS back in the day).
Old Sep 13, 2004 | 07:12 AM
sausage5000's Avatar
sausage5000
the RPMs should be correct for the gear selected. you do not have to go in order. how well you shift is much more inportant than what gear you select. nothing else matters. if that doesn't make sense or is too complicated, trade for an auto.
Old Sep 14, 2004 | 09:01 AM
Hazade's Avatar
Hazade
I go 1-3-5 a lot but mainly because i'm lazy. I don't do it at extremely low rpms to cause bogging or anything like that. besides that would defeat the purpose of higher mpg
Old Sep 14, 2004 | 10:59 AM
jor8888's Avatar
jor8888
350Z has so much torque u can do any combo u want like 135, 124, 14, or even start out with 24, etc.
Old Sep 14, 2004 | 06:30 PM
AZZGUY's Avatar
AZZGUY
I seem to always have trouble starting in 2nd - it always tends to "grab" for me - so always use 1 , but is very smooth to 3 then to 5 - and on to 6 if going very far ,then downshifting is usually slowing down to about 45, then into 5th , the 3rd - which will allow me to slow a lot - then use the clutch to get out of gear and the brake at a light (using very little brake - if the downshifting and slowing is doing at the right speeds and timing. To me this saves on both gas and brakes. Also gives a very smooth slow down and cuts the danger of being rear-ended by a rapid stop or slow down. By doing it this way - the guy behind you knows something is quite different (no brake lights) and usually keeps a more decent distance behind you! lol
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
seagrasser
Oct 11, 2015 03:27 PM
apex locator
Oct 6, 2015 05:58 PM
