SLIP and BRAKE lights keep coming on???
Old Sep 20, 2004 | 10:13 PM
mbonanni1856's Avatar
mbonanni1856
Default SLIP and BRAKE lights keep coming on???
Every time I get into the Z I turnt the VDC off. I noticed today on the way to school that any time the tires would break loose, even a little, the e-brake light and the SLIP light would come on. The VDC did not engage, but the SLIP light stayed on the rest of the way to school. The BRAKE light went off after a coulple off minutes, but would pop back on from time to time. Now every time that the tires break loose those damn lights come on. Has this happened to anybody else. It is going to the shop for service, I would just like to have a good idea of what it is before hand in case they try and screw me.
Old Sep 21, 2004 | 02:30 AM
Z CRUZN's Avatar
Z CRUZN
Check your brake fluid level - both BRAKE & SLIP lights will come on when your fluid level gets low. It will start to occur with quick accelerations & braking as the low fluid level rocks back & forth in the reservoir. Hope this helps.
Old Sep 21, 2004 | 05:23 AM
FairladyZ's Avatar
FairladyZ
exactly your low on fluid, but you really arent. Its a sign your brake pads are going out. When you replace the pads and you push the pistons back into the caliper your fluid level will rise.
Old Sep 21, 2004 | 09:26 AM
JeffR116's Avatar
JeffR116
Or, you refill your fluid, then change your brake pads, and the excess spills out the top. heh.
loudtoyz
Apr 6, 2023 04:52 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
