what to do? wheels or performance???
I don't know about you guys, but I think a nice set of wheels with wider, and MUCH better rubber will make a better difference in handling then some coilovers. The stock rubber is just way too thin, and WAY to crappy! I could not believe the difference S03's sized 245/275 made in handling, like a whole new car.
I would go with suspension also. Some nice swaybars, coilovers and camber adjusters. You will definatly feel less body roll and can be more agressive on the turns with stability. A balance car gives me a smile. But this is me.
I went exhaust first, cause I wanted a better tone. Then went wheels, rubber and springs. If I started again, I would do it like I said in the beginning.
Go with the wheels! I just installed my Nismo LMGT4's and I regret not doing it earlier! It makes such a difference. I wasn't sure if 18's were going to do the trick, but I couldn't be any happier!
Good luck!
Ian
Good luck!
Ian
Thanks for all the input guys. I have been acutally thinking of getting the wheels and doing the tein suspension with the EDIC. Thanks for the tutorial about the camber also. That makes sense now. BTW, threefifty i will be sure to check it out. Thats one hot car.
