Replacing the headlights?
Old Oct 23, 2004 | 09:47 PM
Sully's Avatar
Sully
Default Replacing the headlights?
Gents,
Whats exactly needs to come off, or doesnt for that matter when replacing the headlights?
Also is "H7" the right size?
Thx - Images of the process would be awesome, I rather not rip the thing apart if I dont have too, there always an easy way, and i wanna know it!
Sully
Old Oct 23, 2004 | 11:08 PM
FairladyZ's Avatar
FairladyZ
Are you trying to change the bulb only or remove the whole assembly?
If you want to change the bulb, the best way is to remove your wheel. And you can change the bulbs without removing the headlights.
Old Oct 24, 2004 | 06:31 PM
Jun's Avatar
Jun
I think he means "headlight BULB".
If that's the case:
1. turn the wheel to the left if replacing the left side and vice versa.
2. Pull back the plastic cover and you will see the back of the headlight
3. Counterclockwise, remove the grey cover
4. unclip the top bulb (low beam) and remove the bulb
5. replace the bulb with the bulb of your choice.
6. repeat steps 4 through 1.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
