HP difference in 2005 Track Model
Old Oct 28, 2004 | 12:25 PM
jerkoferson's Avatar
jerkoferson
Default HP difference in 2005 Track Model
What does Nissan do to the Track/35th Anniversary models to bump them up to 300hp?
Old Oct 28, 2004 | 12:47 PM
hbenet's Avatar
hbenet
http://www.nissannews.com/nissan/new...20025101.shtml
Old Oct 28, 2004 | 01:15 PM
KingofScion's Avatar
KingofScion
right but did they change the CAMS? the timing? where does this magical 300 hp come from?
Old Oct 28, 2004 | 04:04 PM
lowrider's Avatar
lowrider
Changed the ECU, slight change in timing, VVT added to exhaust valves, 400 RPM added to Redline.
Lou
Old Oct 28, 2004 | 04:14 PM
Masterfulks's Avatar
Masterfulks
I'm curious to see the new quarter and 0-60 times.
Is the HP worth the loss in torque?
Old Oct 28, 2004 | 04:17 PM
thawk408's Avatar
thawk408
Read the article and it tells you...
The 35th Anniversary Z®’s engine has been modified using revised pistons and camshaft and the addition of electronic exhaust valve timing control.
Old Oct 28, 2004 | 05:25 PM
ALong's Avatar
ALong
Responded to similar post as well but I talked with Nissan Competition to find out what parts are different and was told that the difference is all ECU tuning, otherwise the motors are the same.
Old Oct 29, 2004 | 08:02 AM
Sully's Avatar
Sully
Nice, next question... Who got the new ECU!!!
Sully
Old Oct 29, 2004 | 08:36 AM
damoniusmonk's Avatar
damoniusmonk
I don't think you can add exhaust valve control with an ECU change
There must have been a physical re-routing of timing belts to accomodate the new function
Old Oct 29, 2004 | 04:38 PM
ALong's Avatar
ALong
I was told almost all of the 13hp difference was the ECU tuning, so yes I know it has an exhaust valve control but according to Nissan Comp, its not worth anything HP wise, maybe 1-2.
Old Oct 29, 2004 | 11:54 PM
thawk408's Avatar
thawk408
Probably the reason why it is "mostly" ECU tuning is b/c they had to retune it for the VTC on the exhaust cam. So I bet the VTC on the exhaust help a bit. They also mentioned that it has revised pistons.
Old Oct 30, 2004 | 05:54 AM
ALong's Avatar
ALong
Well, take it anyway you want, but when I talked with Nissan Competition, to find out what parts I needed to update my motor in my racecar, they said it was all ECU tuning and that the new engine parts dont really add any horsepower. So in other words, I was ready to spend money and buy parts and they said dont bother....
