Bumping Noise At Idle
on
When parked, at idle and the transmission in neutral there is a bumping noise that sounds like its coming from the back of the car. Could this be the fuel pump????
on
Originally posted by FairladyZ
This may sound funny but is your radio off when your car is at idle or just barely on when you are listening for the sound?
I noticed the "same" sound a week ago.....first thought it was coming from the engine compartment, raised the hood and couldn't pin point the noise at that location, walked towards the rear and the noise seemed to diminish mid way. Concluded it may be an exhaust leak or exhaust problem and haven't thought about it till I read the post today.
Not familiar with the infamous Nissan exhaust "Pop"......do know the noise I'm hearing is not coming from the exhausts pipes at the chrome tips.
on
Originally posted by Daking350z
is it like this...
Engine running..
Brrrr brrrrr brrrr brrrrr pop
brrrrrr brrrrrr bbrrr pop..
Kind of like a misfire at idle?
is it like this...
Engine running..
Its a lean idle condition...Dont let nissan tell you its normal.Demand you get the NEWEST ECU software as well as the coil packs checked..I had it for many miles then swapped out my ECU and gone..Also had bad coils on my car caused by J&S...
on
Thanks to all who posted in response. This board has been great with lots info.
I had/have the same problem.
A nissan dealer worked it pretty hard the other day installed a MAf and the problem is 50% less now.
Anyone else have any more comments and advice?
I am hopeful my soon to be addition of a grounding kit will fix whats left of my poor idel.
Fred..
Fred..
on
Fred..
Fred..
on
Originally posted by DAYTONA-ZED
Its a muffled sound like someone thumping the bottom of the rear floorpan. sounds like its coming from a little past mid-car back to the muffler area.
I'm still waiting for Technosquare to come out with the F-Spec flash for the '05 models so they can tune my A/F.
on
Originally posted by Superhung
I have the same sound too along with rough idle. Most likely the car is running lean. My idle was extremely smooth until the addition of my mods.
