Rear wiper washer sprayer leaks under hard acceleration!
I don't know if there is a tsb for this or just a part of owning the z, but whenever I do moderate to hard acceleration in the z from a standstill the rear washer sprayer streams a big old line of washer fluid down the middle of the rear glass. Normally this is of no concern, however if your vehicle is clean and this happens it makes the rear look like crap. Anyone else have this issue? I think my z needs a pair of depends !
Ah, did a search, looks like this has been discussed previously, however, no definitive word on if there is a fix or if this is another z characteristic that we need to live with. I might just disconnect the whole washer wiper setup in the back since I never use it.
Originally posted by AZZGUY
No, I would day your Z is DEFINITELY different. In Arizona we probably wouldnt worry about that problem - just not fill the tank for the rear window washer. It seldom rains here! Had my Z since Feb - havent used that rear wiper yet! (not to say I havent used the front one a few times)
I've had my Z for almost 9 months now and I had the leak happen yesterday. I've never used the sprayer until a couple of weeks ago when it was raining. It never happened until then. It's really annoying. Something new to tell my dealer, I guess.
Mine's in the shop today for that and a couple other minor annoyances. It will be interesting to see what if anything they do about it.
Gotta love this conversation though...
"My rear washer leaks sometimes".
"When?"
"Only when I accelerate at full throttle in first and slam it into second".
"Okay, we'll check it out..."
"When?"
Yup, that's just what I am afraid of: some meat popsicle at the dealer tearing up my new Z. This is the worst part of owning a new car, visiting the dealer and having apathetic, obtuse ***** manhandle our rides. Let me know how it goes, I might just disconnect the tube, or perhaps I will zip tie the tube to put a kink in it, reduce the flow back there.
I have noticed this too.... REALLY annoying. I have a SB, and right after I clean it I usually drive with somewhat more.... ahem... "spirit". And then when I get home I gotta get out the quik wipe detailer and microfiber to get it off before I get water spots. I hate that.
I talked to the SA a little while ago, naturally they couldn't reproduce the problem.
I never use it anyway, I'll just drain the tube and leave it like that so there will be nothing to come out. Maybe I'll put a little stopcock inline so I can turn it on later if necessary.
I get this too. Very annoying and generally only happens AFTER the car gets waxed and shined!
Might just cap it up with the tip of a condom or something?
Hey...that just might work.
Originally posted by Superfly84zx
there is some kind of check valve that is defective. I've read this on forums before...I think its a common problem on the older cars....
this used to happen to my z (early 04) all the time and bug the shiat out of me. it does not happen anymore.
here's why it happens: when you're taking your right hand off the wheel to shift gears, you're tapping the control bar on the right side of the steering column, which activates the rear spray pump for a fraction of a second (it's way too sensitive). this is more likely under hard acceleration, when your body is being jerked back and forth while shifting. so, don't do that anymore and your car will remain clean.
just noticed it last night after a month...
i don't think it can handle the speed, may look into pinching the tube somehow in the service manual...it'll probably be a pain in my arss
This used to happen to my '98 Integra GSR...I hated it...cause it was a black car, so I feel your pain.
I haven't had it happen on the Z...And I'm quite happy about that!
I use my rear washer often too...so not sure what's up with your cars.
