2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Lets Talk Pumpkins! (Final drive gearing for the 370z)
Old Oct 29, 2008 | 08:06 AM
sq40's Avatar
sq40
Originally Posted by OldDirty Z33
With the 4.08 how much top end would you lose? My guess would be top speed of 140??
According to this Thread;
https://my350z.com/forum/engine-driv...installed.html
STOCK 3.357 Gear-- ECU REFLASH 3.357 ---HR Engine
6600 Rpm Redline --------7200 Rpm Redline----------7500 Rpm Redline
First------40mph ------First-----44mph-----------First-----46mph
Second ----66mph ------Second----71mph-----------Second----74mph
Third------94mph-------Third----102mph-----------Third----107mph
Forth-----120mph-------Forth----131mph-----------Forth----136mph
Fith------152mph-------Fith-----166mph-----------Fith-----173mph
Sixth-----192mph-------Sixth----209mph-----------Sixth----218mph
STOCK 3.538 Gear-- ECU REFLASH 3.538 ---HR Engine
6600 Rpm Redline -------7200 Rpm Redline-----------7500 Rpm Redline
First -----38mph ------First-----42mph-----------First-----43mph
Second ----62mph-------Second----68mph-----------Second----71mph
Third -----89mph-------Third ----97mph-----------Third----101mph
Forth ----114mph-------Forth----124mph-----------Forth----129mph
Fith -----144mph-------Fith-----158mph-----------Fith-----164mph
Sixth ----182mph-------Sixth----199mph-----------Sixth----207mph
No Reflash 3.7 Gear-- ECU REFLASH 3.7 ----HR Engine
6600 Rpm Redline ---------7200 Rpm Redline---------7500 Rpm Redline
First -----36mph-------First ----40mph-----------First-----41mph
Second ----59mph-------Second----65mph-----------Second----68mph
Third -----85mph-------Third ----93mph-----------Third-----97mph
Forth ----109mph-------Forth----119mph-----------Forth----124mph
Fith------138mph-------Fith-----151mph-----------Fith-----157mph
Sixth-----174mph-------Sixth----190mph-----------Sixth----198mph
No Reflash 3.9 Gear -- ECU REFLAH 3.9-----HR Engine
6600 Rpm Redline ----------7200 Rpm Redline-------7500 Rpm Redline
First ------35mph-------First ---38mph-----------First-----39mph
Second -----56mph-------Second---62mph-----------Second----64mph
Third ------81mph-------Third----88mph-----------Third-----92mph
Forth------103mph-------Forth---113mph-----------Forth----117mph
Fith-------131mph-------Fith----143mph-----------Fith-----149mph
Sixth------165mph-------Sixth---180mph-----------Sixth----188mph
No Reflash 4.083 Gear-- ECU REFLASH 4.083--HR Engine
6600 Rpm Redline ------------7200 Rpm Redline---------7500 Rpm Redline
First ------33mph--------First ---36mph----------First-----38mph
Second -----54mph--------Second---59mph----------Second----61mph
Third ------77mph--------Third ---84mph----------Third-----88mph
Forth ------99mph--------Forth---107mph----------Forth----112mph
Fith ------125mph--------Fith----137mph----------Fith-----142mph
Sixth -----158mph--------Sixth---172mph----------Sixth----179mph
Old Nov 4, 2008 | 08:40 AM
buynissanparts's Avatar
buynissanparts
Looking at the parts catalog, they show 2 gear sets, but give no ratio. also the limited slip is a viscous.
thanks
Old Nov 4, 2008 | 11:10 AM
trebien's Avatar
trebien
thanks
It would be interesting if there is a different gear set available as an option, like for a track model. So those that want the reduced economy but better acceleration would have the option, or it comes standard with the 3.9 ratio. Hell, this thing will be fast as it is... maybe for the NISMO version.
But I would assume now with the 7AT in the 370Z, each tranny gets a different gearset. The 7AT in the G37 gets a new 3.357:1, and the 6MT remains with the old 3.69:1 that both the 6MT and 5AT had.
Considering that the 7AT G37 is posting the same performance as the 6MT G37, I bet these ratios will be mimicked in the 370Z. After all, the first 4 gears in the 7AT are much more aggressive than the 6MT.
Old Nov 12, 2008 | 12:44 AM
Doc25398's Avatar
Doc25398
I guess like others have mentioned earlier it would depend on the max RPM the engine can handle. I am not sure if it will rev higher than the HR's since its a larger motor I would of thought the rpm would not be as high. However GTM makes a stroker kit that can rev higher so anything is possible. Does anyone have any speculation on that?
Old Nov 12, 2008 | 02:23 AM
Kwame's Avatar
Kwame
A stroked motor can rev just as high as an un-stroked motor. The thing is that it generally doesn't need to rev high since it makes its power earlier on in the rpm range compared to an un-stroked motor and its power also tends to fall off earlier off in the higher rpms as well.
Old Nov 22, 2008 | 10:45 AM
Mcdaddygolf's Avatar
Mcdaddygolf
Default Quick question
Hey guys,
I just stumbled onto this thread because I was considering switchiing out my "pumpkin" in my 07' 350z base. I was wanting limited slip diff. and did not consider the change in top end. I do alot of highway driving and cruising at 80 with the tach around 2500-3000 is nice for gas. should I just keep what I have since i don't race and rag my car. Thanks, Cris
Old Nov 22, 2008 | 10:50 AM
Steve-O Z33's Avatar
Steve-O Z33
Where can we get the higher gear sets? I have only seen 350evo or whatever it is and their price seems high to me for what you get.
Old Nov 22, 2008 | 10:51 AM
Kwame's Avatar
Kwame
http://z1auto.com/submodel.asp?model=350z&cat=driveline
Old Nov 22, 2008 | 10:57 AM
Kwame's Avatar
Kwame
Originally Posted by Mcdaddygolf
Hey guys,
Cris,
Are you looking into installing an LSD into your base model car? or are you looking into swap out your final drive?
If all you are looking to do is install an LSD you can do so and it will not affect your current final drive. Therefore whatever RPMs your car normally operates at will remain the same, your top end will also remain the same. You will see a dramatic increase in handling by installing a Limited Slip Differential (LSD) into your car. I hope this answers your question, PM if you have any more.
Old Dec 30, 2008 | 11:07 AM
sbkim's Avatar
sbkim
Sorry for dumb question but will LSD (sport pkg) improve straightline accerleration?
Also, any final info on gearing for 7speed auto - will it be the same as G37?
Thanks
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
