is the softop okay in SNOW??????
Yeah, the top if just fine in the snow. I would recomend putting protectant on it before you go, but you've probably already done that. The top is made to handle all weather conditions though and you will be fine.
nope i have not put protection on it yet.......ahhahaha......but where can i get this 303 stuff....or will any vinly protectant work....i do have the meguiers NXT protectant....will that do....
thanks
thanks
Originally Posted by KouSport
i might have to drive to reno next week.....how does our top hold up towards snow??????
thanks
thanks
Not to mention that if it snows and the road is icy, you have to watch out for fools straying/spinning into your lane.
Thats good advice. If you encounter below zero temps and there is precipitation. Drive very carefully or better yet, park your Z until the salt trucks arrive or you will get in an accident.
The weight. But i had 2.5 ft on my top, didn't bother it a bit. At a cabin over
the weekend, had to put cables on tires, but it didn't help much. Still had
to get pulled out to plowed road. Scary drive down the mountain.
Snow on your top is the least of your problems. Without snow tires or chains you are screwed. If snow is deep your screwed even with snow tires and chains. Z's were not designed to plow through snow.
