Wing
Old Feb 24, 2007 | 09:54 AM
daZgirl's Avatar
daZgirl
Default Wing
I'm having a Stillen wing mounted on my Roadster next week, but the paint shop is concerned about mounting it with just double-stick tape. Anyone have a better way of mounting it without destroying the trunk lid or wing? I want to be sure the sucker stays in place and doesn't give me issues later.
Once it's mounted I'll post some pic's.
The paint shop also had concerns about the wing being rubber. They're afraid the paint won't look right.
Old Feb 24, 2007 | 05:57 PM
Phantom Menace's Avatar
Phantom Menace
Paint does not normally bond well with rubber. Usually, it ends up peeling or flaking off after a while. Notwithstanding, there are some types of paint that will flex with rubber but in the end will not bond as well with other materials.
The only other way to mount it, other than double-sided tape, is to drill some holes on your hatch/trunk lid and bolt it on. This is the best way if you are committed to that style of spoiler and do not anticipate ever chaning it or taking it off.
Hope this helps.
Old Feb 24, 2007 | 06:12 PM
918 Z's Avatar
918 Z
use 3m double sidewd tape. the guy i bought my car from had six holes drilled into the hatch....i cant wait to fix it.
Old Feb 25, 2007 | 05:06 PM
Barmats's Avatar
Barmats
The Stillen spoiler is urethane, which is a flexible plastic polymer. I suppose it's similar to rubber but technically it's different (not quite as flexible). I'm also considering a Stillen Type 1 spoiler and Stillen says there's no problem having it painted. Once it's mounted, it shouldn't flex enough to cause any paint adhesion problems. Make sure it's primed before the paint. Post pics when you get it mounted!
Old Feb 25, 2007 | 05:09 PM
LvntheZ's Avatar
LvntheZ
if they think its the best way let them do it but make sure you ask them what kind of warranty comes with it.... just incase it flys off.... or paint chips or stuff like that..... other than that its all about the good ol drill and screws
Old Feb 25, 2007 | 07:45 PM
CAN0802's Avatar
CAN0802
You will not lose the wing if they attach it with 3M tape. One inch is supposed to hold 5 pounds. Line the wing with it, and the only fear of it comign off would be if you hit warp speed.
Old Feb 25, 2007 | 10:23 PM
LaoSiFu's Avatar
LaoSiFu
I used 3m double sided tape on my spoiler and it hasn't given me any problem. I bet you'll be fine.
Old Feb 26, 2007 | 03:37 AM
Firehawk's Avatar
Firehawk
Sounds like you need to find a different paint shop.
Old Feb 26, 2007 | 10:24 AM
usarmyttt's Avatar
usarmyttt
I just put one on my car...here is my suggestion.....drill the holes as Stillen requests. I did not and had a few gaps from using the tape so I had to go and drill them from the bottom. I missed the right locations twice, you do not see it but IF that thing ever has to come off I am going to need some serious work on the hatch.
Finally, if this is what you want, do it as the manufacturer says. Great looking spoiler btw. Search my name and you wil see mine.
Good luck!
Old Feb 27, 2007 | 06:24 PM
daZgirl's Avatar
daZgirl
thanks for all the replies. I got a lot of great responses.
I'll go with the 3m tape, and have the shop use the screws also.
Good one, can0802. But, it could happen.....warp speed, I mean....maaaaybe.
Old Feb 28, 2007 | 01:35 PM
Built2shredZ's Avatar
Built2shredZ
The shop that installed mine also had concerns about the 3m tape, so they ended up using polyurethane glue (the stuff they use to assemble corvettes), that sucker is on there for life now lol....
I've had mine on for 3 years now and so far no problems with paint issues...
Old Feb 28, 2007 | 02:52 PM
beggohbee's Avatar
beggohbee
Mine's on with just tape and I have no problems with it. I was worried at first too, but after almost a year of driving and opening/closing the trunk, I'm pretty sure it ain't coming off anytime soon!
Extreme Dimensions
Body Exterior
Nov 9, 2015 10:47 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
hardkicks
Sep 20, 2015 12:28 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
