Help!!!05 roadster
Old Apr 14, 2008 | 07:20 PM
QUADZILLA's Avatar
QUADZILLA
Default Help!!!05 roadster
On any hard right turn the VDC OFF , SLIP , AND BRAKE LIGHT come on. The break light will go out, but I have to turn the car off to reset the VDS , SLIP lights. I have new tires in the rear and prolly 80% in the front. Do I need to look at the brakes for an issue?.....Once again its ONLY when I get on it taking a right turn...tach maybe 5k
Old Apr 14, 2008 | 07:36 PM
johns350's Avatar
johns350
Sensor malfunction? Just a guess.
Is it repeatable?
By the way - tach at 5,000rpms??
Old Apr 14, 2008 | 07:55 PM
bluespecv03's Avatar
bluespecv03
What size tires are you running?
And sometimes when I do donuts(or when I used to), those lights would come on for me. Guess its just the drastic difference in speed between the front and rear wheels.
Old Apr 14, 2008 | 08:18 PM
xtrmspd's Avatar
xtrmspd
I have an 06 roadster and I don't have that problem. I did however, had that problem when one of the wires popped out of the Stillen SC piggy back. It's fine now.
So it may be a wiring issue or a sensor as Johns350 stated.
Bluespecv03: Bigger tires don't make the lights go on.
Old Apr 15, 2008 | 05:27 AM
QUADZILLA's Avatar
QUADZILLA
maybe not 5k but coming out of the right turn in 2nd.. going to third these light come on every time...seems to be happening more frequently...I have stock wheels with toyo proxies...havent changed the size...I do drive aggressive and if I take it slow the problem isnt there....I could understand if it were one or the other but not all three....hate to bring this to the stealership...Anyone know of a good shop in the Dallas area??
Old Apr 15, 2008 | 01:27 PM
bluespecv03
Im pretty sure Ive read that having the wrong size tires front and rear, or the wrong percentage difference, will at least cause the SLIP light to come on. Just checking anyway...
Old May 26, 2008 | 04:45 PM
calbert's Avatar
calbert
New to the site and came across this thread. i have the same issue when I drastically slow down on the highway in the rain. Any ideas?
Old May 26, 2008 | 05:47 PM
DavesZ#3's Avatar
DavesZ#3
Low brake fluid. Worn brake pads.
Old May 31, 2008 | 07:48 PM
Blooster's Avatar
Blooster
Wrong tire size can make SLIP light go on - read:
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
MAsSIVrOOM
Oct 20, 2023 10:50 AM
jlb
Oct 15, 2017 05:10 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
416blueZ
Sep 25, 2015 10:00 AM
