How to keep top functioning after a long winter of nonuse??
Old Jan 22, 2009 | 04:57 PM
kenpo_350Z's Avatar
kenpo_350Z
[QUOTE=sluggoZ;6849491]Yeah...& maybe adding more stress on the material & it starts separating at the seams.
Sadly this is probably true since i just had to have mine patched but no more messing around.
Old Mar 23, 2011 | 09:34 AM
murders's Avatar
murders
wow, dont wanna mess up top, glad to find this thread.
Old Mar 23, 2011 | 04:45 PM
gregom's Avatar
gregom
Don't put the top down under 45 deg Fahrenheit, I think the manual says that doesn't it? The soft top material is harder and causes stress on the motor when trying to open/close in cold temperatures. BTW when you try to put the top down when it is cool, 45 F to 60 F and it stops 4/5 the way, just send the close command for a second, then start the open command again. It should complete... The motor is programmed to stop if it encounters too much resistance, and sometimes in the cool the stiff soft top material creates enough resistance to cause the motor to stop.
Get a dry silicone based lubricant, and apply it with your fingers into the locations where parts move.
Old Mar 31, 2011 | 09:57 AM
sluggoZ's Avatar
sluggoZ
Here's what I use on all moving hinge parts....
Attached Thumbnails How to keep top functioning after a long winter of nonuse??-primisgel.jpg
lapham3
Oct 7, 2022 03:15 PM
Justin100
Nov 25, 2021 06:26 AM
3vilbunny
Jul 18, 2017 05:10 PM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
