How to keep top functioning after a long winter of nonuse??
Any suggestions haven't had top down in months any regular maintenance that should be performed on it??
Oil all hinge points. Oil and/or grease the track at rear-most of the top (bow motor? I forget what it is called right now..)
Good Luck.
PS - if anyone has been able to find the 'lube-gel' - let us know where/how much/etc..
Good Luck.
Regarding the other post - no idea how much the dealer would charge to oil/lub it - but it's not a difficult task...
Good Luck.
Lol how cold is cold. It is so tempting sometimes. The only time my top gave me some trouble was when it was really cold. I hit the button heard some noises but nothing. I about shat. But the tried again and it worked. Then again when it was finally warmer and it didn't miss a step. It better not be going out.
I just want to make sure the motors and hinges are lubed/oiled.
What many people were using is Primis Lube Gel. BUT - cannot find it any longer.
I've used a plain Silicone spray being careful on the overspray. It has helped.
If anyone can locate the Primis stuff, please let me know.
Thanks
Thanks
I put my top down today and had to open and close it a few time for the hatch to shut on the top. It was about 30 Deg not to chilly with the heat on and the leather seats as well.
About 45 degrees this morning - my top opened about 4/5ths and then stopped and refused to go lower. I was a stop light too - I must have looked like a right tit as I put it back up grrr. Worked fine later on.
That definfitly does suck, I know how that feels. I never drop the top at lights anymore for that reason, histerical comment "right tit" !!!
......I'll just wait for warmer weather!
ZR
sluggoZ you are very correct! I just had a small tear patched up today. I was also told that running the top in cold weather is very bad because the hydrolic pump oil will be too cold and that is why the top stops mid-air or you hear noises and nothing happens. Then you burn up the motors. Not good!
Guys....why take chances! It's not worth it unless your living the real 'American Dream' where money is no issue.
OoOh Yea!
