Cleaning and Protecting the Roof off a Roadster
Old May 6, 2009 | 09:07 AM
emilio2009's Avatar
emilio2009
Default Cleaning and Protecting the Roof off a Roadster
Hi, just picked up an 04 350ZR Grey with Blacktop, and wondering what you use to protect the roof and to make it look new. The black roof looks good but fades after a day or two from being washed. Any suggestions? Emilio
Old May 6, 2009 | 09:53 AM
Xzero's Avatar
Xzero
http://www.303products.com/tech/inde...Product_ID=430
Get the vinyl kit.
Old May 6, 2009 | 11:42 AM
iStan's Avatar
iStan
ZR
^I was going to say 303 too.
Old May 6, 2009 | 12:02 PM
myork's Avatar
myork
Why would you get the vinyl kit, arent all the z tops cloth?
I used the 303 Cloth kit and it worked well for me, but the protectant needs to be wiped to get the coverage even. When I followed the directions on the bottle I wound up with dark patches, so I tried evening it out with a damp cloth by dragging it front to back so the coverage was uniform. Looks perfect now.
Seems to repel very well so far, but it has only been a month or so. But in that month it has rained quite a bit here in NJ.
Old May 6, 2009 | 02:55 PM
ZR_Yancy's Avatar
ZR_Yancy
NO
Old May 6, 2009 | 03:11 PM
emilio2009's Avatar
emilio2009
Thanks for the info...so Vinyl or cloth kit?
Old May 6, 2009 | 03:24 PM
Master Shake's Avatar
Master Shake
Vinyl.
Old May 6, 2009 | 03:28 PM
ZR_Yancy's Avatar
ZR_Yancy
Vinyl
Old May 6, 2009 | 08:08 PM
myork's Avatar
myork
I'm confused - why does the owner's manual say that the top is cloth:
Soft top care and cleaning (Roadster
models)
Proper care and handling should be observed to
maintain a good appearance of the soft top.
Improper care may cause the top cloth’s surface
to stiffen, stain, or mat. Follow the instructions
shown in this section.
It is not necessary to wash the soft top every
time you wash the vehicle body, but clean the
top regularly before it becomes quite dirty. Leaving
the soft top dirty or soiled for a long period
will cause deterioration to the quality of the top
material.
Remove dust or dirt on the soft top with a soft
brush or sponge, then rinse it with plenty of
clean water. When the top is quite dirty, wash
using a mild detergent, such as a general
cleaner especially made for a cloth top or a
general purpose dish-washing liquid, mixed with
clean, lukewarm (never hot) water. Rinse the top
again with plenty of clean water to remove all
traces of soap.
That is from the 04 manual but the 06 says the same thing:
http://www.nissanextendedwarranty.co...issan-350Z.pdf
Old May 7, 2009 | 10:35 AM
Master Shake
models)
material.
traces of soap.
Excellent point, but take a look at this:
http://www.350zmotoring.com/forums/g...top-vinyl.html
Old May 7, 2009 | 11:21 AM
myork's Avatar
myork
WOW - that info should be stickied at the top of this section!
Do you think the fabric protectant will hurt the vinyl?
I bought it online at autogeek, maybe I'll give them a call just to be safe.
Old May 7, 2009 | 01:15 PM
myork's Avatar
myork
OK so I called 303 Products directly, and spoke to their tech guru Roger.
The good news is that the fabric conditioner will not hurt a vinyl top in any way.
The semi-bad news is that since it is designed to be long lasting, unless I want to use an abrasive to get it off (which I dont and Roger does not recommend), its going to be 5-6 months before I can treat the top correctly. Putting a vinyl protectant over the fabric conditioner wont do anything, so I will have to wait until the fluoropolymer wears away due to the elements.
Roger did say that after a few months try a small area with vinyl protectant, and if the spot looks more "lustrous", then the fabric guard is wearing off.
At least Nissan's reluctance to divulge the type of top material didnt cause any harm.
Old May 7, 2009 | 01:54 PM
yogipower's Avatar
yogipower
Originally Posted by Xzero
thanks =)
Stevo Z
Oct 3, 2015 09:14 PM
_bit
Oct 2, 2015 07:49 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
SharX59
Sep 27, 2015 09:23 AM
