A/C failed
Old Apr 13, 2010 | 07:12 PM
fklentz's Avatar
fklentz
Default A/C failed
So I'm driving down the freeway and I smell this funny smell, I think it's not me, then I see smoke comming out from the vent on my hood and start to panic. I check my gauges, everything looks OK, car runs fine engine cool good oil pressure. I park pop the hood and see what I first thought was coolant (green) dripping in the area of the coolant into the thermostat but no steam. Checking further I realize it's A/C oil with green leak detector.
I think the seal blew on the compressor but it's going to be a PITA to fix.
Old Apr 14, 2010 | 06:43 AM
diablox1's Avatar
diablox1
who needs AC
Old Apr 14, 2010 | 04:49 PM
Revboyz's Avatar
Revboyz
Dude that is a PITA. I had that happen to me when I had a Bimmer.
Old Apr 15, 2010 | 05:09 PM
fklentz's Avatar
fklentz
Found the problem, the A/C belt failed and half of it came loose and whipped the tar out of the compressor discharge hose till it tore thru. What pisses me off is I KNEW my belts needed changing and HAD a set ready with new tensioners and just kept putting it off, either it was raining or the weather was too nice to be working on the car. Well now the belts are new and the tensioners, I think I can cut the A/C hose and clamp it with a piece of tubing as to replace it I think I'd have to change the condenser.
Rule 1: don't put off changing belts, they're cheap, easy and quick to change.
Old Apr 15, 2010 | 05:56 PM
fklentz's Avatar
fklentz
There is a disconnect between compressor and condenser, just ordered the hose and disconnect tool from courtesyparts. I just gotta have A/C.
350z_z33.
Jul 3, 2017 04:01 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
h8redlights
Sep 11, 2015 07:57 PM
emu29
Jul 16, 2003 07:51 PM
Ohio350z
Oct 24, 2002 06:35 PM
