Eibach Prokit - Different for Roadster than coupe?
Old Jan 13, 2011 | 05:04 AM
Skolastix's Avatar
Skolastix
Default Eibach Prokit - Different for Roadster than coupe?
Is there a different kit for the roadster or are they the same? I know that the roadster is heavier so I would assume there would be a different kit, but I am not sure.
Before anyone asks, searched for the Eibach Pro-kit for the Roadster and only found one relevant thread that had VERY mixed opinions...and it was from 2006
Thanks for your help gang!
Old Jan 13, 2011 | 09:34 AM
myork's Avatar
myork
Pretty sure the p/n is the same for coupe or roadster.
Old Jan 23, 2011 | 06:10 PM
Figs350ZR's Avatar
Figs350ZR
I've talked to Eibach directly... they're the same for both coupe and roadster.
Old Jan 23, 2011 | 07:48 PM
Skolastix's Avatar
Skolastix
Awesome Figs & York. Thanks!
Old Jan 23, 2011 | 08:29 PM
Figs350ZR's Avatar
Figs350ZR
No problem. They even said that if you don't want to change out your stock shocks (can't afford, have low mileage, or don't know which ones to go with) then it'll still ride fine, since the stock Z shocks are fairly progressive to begin with. Also, if you go w/ a set that drops your ride more than .8" you'll have camber issues, so keep that in mind and how that'll affect tire wear and overall life of the rubber you're riding on!
Hope this helps! Good luck! I've yet to but a kit from Eibach, but when I do, I'll put up before/after pics on here!
Old Jan 24, 2011 | 04:48 AM
Skolastix's Avatar
Skolastix
Yeah, I've read that regarding the shocks. I'm going to get at least some rear camber adjustments this year and do the fronts next year.
I'll post some pics once done. I'm getting some 20's and the drop this year. Body kit and more next year.
This car is going to bleed me dry lol!!!
jlb
Oct 15, 2017 05:10 AM
Jambo016
Sep 16, 2016 01:08 PM
seagrasser
Oct 11, 2015 03:27 PM
