Convertible top wont move at all
Old Jul 5, 2018 | 05:45 PM
dudegetalife's Avatar
dudegetalife
Originally Posted by Boderjoe
[center]
hi i see you had the same problem iam having at the moment my nissan 350z soft top wont go down not the window nothing do no sound at all. Can you let me know how you fix your problem with your car.. thanks
it was a sensor beside the soft top on the driver side. Some kind of switch/sensor that cost about 40/50? Dont remember what it was called got it from Nissan dealer. The techs were useless had a independant mechanic figure it out.
Old Jul 5, 2018 | 05:50 PM
Boderjoe's Avatar
Boderjoe
Originally Posted by dudegetalife
Update:
Insurance wouldn't cover top since it was preexisting condition.
Nissan wants 8k in parts before they start work on it.
Got second opinion besides nissan saying top was installed improperly
Gonna more than likely go to court with upholstery shop.
Still dont know issue.
no just soft top material was being replaced tech said that it could be a switch it was done at an upholstery shop but he said it moved up and down and after 2 times it just didn't wanna move at all.
Its an upholstery shop so they dont do any car repair work at all and i've never had this problem at all.
Does our car have a fuse or relay for the top?
the sensor is located by the driver size fuse box
Old Jul 5, 2018 | 05:51 PM
dudegetalife
no definitely not that one had to open up top compartment behind the driver side it's some weird sensor switch took about 20 minutes to replace watched the mechanic do it the whole time.
Old Jul 5, 2018 | 05:56 PM
Boderjoe's Avatar
Boderjoe
Ok.. thanks i will check tomorrow.
Old Jul 5, 2018 | 06:59 PM
Boderjoe's Avatar
Boderjoe
After having my top replaced the convertible top wont move at all is their any fuse or relays that control the tops function?
It was working before and now it just doesn't move or make a sound any help would be greatly appreciated.
hi iam having the same problem with my 350z softop wont move at all no window come down nothing do. Can u let me know how u fix your problem.. thanks
Old Jul 14, 2018 | 06:20 AM
msk59's Avatar
msk59
5 Year Member
So Dudegetalife. I read your struggle and confirming your last post. so this entire time, this one wierd sensor was causing the top not to go down? There was no other fault like top was installed wrong etc?
Old Jul 14, 2018 | 05:32 PM
Boderjoe's Avatar
Boderjoe
can u tell me where is that sensor wire located.. thanks
Old Jul 15, 2018 | 02:59 PM
msk59's Avatar
msk59
5 Year Member
Boderjoe:Not understanding your question. I think in post #22, you are answering that question.
Old Nov 30, 2018 | 07:42 AM
Chuck Levy's Avatar
Chuck Levy
Fuses all good. Can’t find box behind driver’s seat. Opened panel, but didn’t see it.
Old Nov 30, 2018 | 07:46 AM
Chuck Levy's Avatar
Chuck Levy
2004 Nissan 350z roadster top won’t operate at all
Old Dec 5, 2018 | 06:48 AM
Heel Til I Die's Avatar
Heel Til I Die
There are a lot of conditions that have to met for the top to begin opening from full close. I would highly recommend downloading the RF section of the FSM to help you troubleshoot.
Old Dec 11, 2021 | 07:55 AM
laneb101's Avatar
laneb101
Default Thank you for the answer!
I just bought my 350Z in Seattle and had it shipped to Florida. The top worked there but when I got it off the truck, it wouldn’t budge! I was freaking out but read your answer, put my foot on the brake and it worked!!
Originally Posted by SparkleCityHop
Thanks for such a helpful post.
But back to the business at hand...
Do the windows come down and does the passenger seat move when you attempt to operate the top, or does nothing at all happen?
Since it sounds like you're not a new owner - I'm already assuming that you have key in the ignition, car is stopped, foot is on brake, and you're holding down the button through the whole process.
Old Dec 12, 2021 | 06:27 AM
msk59's Avatar
msk59
5 Year Member
You are welcome laneb101. Yes, car in neutral/park, foot on the brake with e-brake engaged, then the top opens after you unlatch at the front. The windows do go down if they are not down already. So I think you got it now. I dont drive my car that often and i built a garage for it and it sits in that heated garage most of the time. Since COVID almost two years ago, we have been working from home and not much to do. I do have a frontier that I use around town.
Old Jan 26, 2022 | 09:22 PM
Justang99's Avatar
Justang99
Default Similar issue…
If your windows don't even come down, it sounds more like a fuse issue or problem with the main control unit itself. In my experience, when there is a problem with a component in the top mechanism or a sensor, everything else works as expected until it gets to the step that it needs to interact with the broken item.
Since operating the switch normally rolls down the windows first and leans the passenger seat forward, I would expect that it is either the control box for the entire system or a fuse. the control box for the system can be accessed by taking off the interior panels behind your seat. it is a plastic box that is mounted to the top of the metal and sits above the driver side cubby hole area.
I'm not sure exactly which fuse covers this mechanism, but I would check all fuses in the driver floorboard and under the hood near the battery.
I’m having a similar issue. The windows roll down, but the passengers seat no longer moves. All that happens is a click sound like a relay in the doors… I have removed and reseated the door panels recently. Is there something I might’ve not hooked back up? Every function of the door and window controls work
Old Jan 27, 2022 | 10:12 AM
jhc's Avatar
jhc
General & Tech Moderator
Check the switch on the back of passenger seat to make sure the tilt feature is enabled.
Old Jan 27, 2022 | 04:41 PM
Justang99's Avatar
Justang99
That worked! Thankyou!
Old May 19, 2022 | 05:02 PM
rtfutrell97's Avatar
rtfutrell97
I’m having this problem now do you know what i need to do
Old May 20, 2022 | 10:01 AM
  #38
Heel Til I Die
What's the specific problem - windows roll down, passenger seat moves, top moves at all?
Old Aug 22, 2022 | 10:35 AM
  #39
ZHeadaches's Avatar
ZHeadaches
I seem to be having a similar problem with my Z convertible top - any chance you can direct me to the mechanic who fixed yours.
Old Sep 11, 2022 | 04:54 PM
  #40
rtfutrell51's Avatar
rtfutrell51
the windows won’t move at all the person that had the car changed the seats into some manual seats and kept the white box but its still not working
