Convertible top wont move at all
Old Aug 26, 2011 | 04:57 PM
dudegetalife's Avatar
dudegetalife
Default Convertible top wont move at all
After having my top replaced the convertible top wont move at all is their any fuse or relays that control the tops function?
It was working before and now it just doesn't move or make a sound any help would be greatly appreciated.
Old Aug 26, 2011 | 06:16 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Was any other work done or anything else changed? Seats, windows, window motors, etc.
Old Aug 26, 2011 | 07:17 PM
dudegetalife
no just soft top material was being replaced tech said that it could be a switch it was done at an upholstery shop but he said it moved up and down and after 2 times it just didn't wanna move at all.
Its an upholstery shop so they dont do any car repair work at all and i've never had this problem at all.
Does our car have a fuse or relay for the top?
Old Aug 26, 2011 | 11:16 PM
R350Zz33's Avatar
R350Zz33
should have got a coupe
Old Aug 27, 2011 | 05:19 AM
SparkleCityHop
Living in 350Z
Thanks for such a helpful post.
But back to the business at hand...
Do the windows come down and does the passenger seat move when you attempt to operate the top, or does nothing at all happen?
Since it sounds like you're not a new owner - I'm already assuming that you have key in the ignition, car is stopped, foot is on brake, and you're holding down the button through the whole process.
Old Aug 27, 2011 | 06:35 PM
dudegetalife
ya 5th year owning first major problem do everything and hit open switch no movement whatsoever windows dont even move.
Old Aug 27, 2011 | 06:45 PM
dudegetalife
number 10 and 40 fuse both good where is this power control unit?
Old Aug 27, 2011 | 06:50 PM
dudegetalife
trying to locate power supply for top it looks to be under the roof enclosure anyway to open it without any power?
Old Aug 27, 2011 | 07:52 PM
dudegetalife
http://www.nicoclub.com/FSM/350Z/roadster/2004/rf.pdf
page 39 step 2
i have a multimeter attached red to wire #1 and ground/black wire to the metal of the car i'm not reading anything but i may be doing it wrong any advise?
Old Aug 27, 2011 | 09:51 PM
dudegetalife
5th. Bow couldn't b causing this could it?
Still on same step leaving car in garage for night torn apart any help greatly appreciated
Old Aug 28, 2011 | 03:35 AM
SparkleCityHop
Living in 350Z
If your windows don't even come down, it sounds more like a fuse issue or problem with the main control unit itself. In my experience, when there is a problem with a component in the top mechanism or a sensor, everything else works as expected until it gets to the step that it needs to interact with the broken item.
Since operating the switch normally rolls down the windows first and leans the passenger seat forward, I would expect that it is either the control box for the entire system or a fuse. the control box for the system can be accessed by taking off the interior panels behind your seat. it is a plastic box that is mounted to the top of the metal and sits above the driver side cubby hole area.
I'm not sure exactly which fuse covers this mechanism, but I would check all fuses in the driver floorboard and under the hood near the battery.
Old Aug 28, 2011 | 08:11 AM
dudegetalife
switch is good line to switche is good page 40 step 4 connector circuit i can't get a continuity check on.
Also for future reference nissan ****ed up this service manual wire locations are all misplaced
Old Aug 28, 2011 | 08:48 AM
dudegetalife
99% sure its the entire computer for the soft top i'm gonna take it to nissan tuesday to verify my findings.
Old Aug 28, 2011 | 01:55 PM
SparkleCityHop
Living in 350Z
Man, that bites. Hopefully that will fix the issue, but I'm sure the stealership isn't going to give that computer away unless you pay until it hurts.
Old Aug 28, 2011 | 08:05 PM
dudegetalife
ya i'm gonna bring some lube along as well cuz its gonna hurt.
Old Sep 2, 2011 | 10:18 AM
Rated Z's Avatar
Rated Z
Default Lube Job
Pretty much having the same issue. Browsed my copies of the service manuals and have to admit I'm curious to see what was the outcome after bringing your car in.
Old Sep 6, 2011 | 09:02 AM
dudegetalife
wrecked the z on the passenger side insurance covering everything but wont be ready for a week or so i'll post outcome.
Old Sep 27, 2011 | 10:43 PM
Resmarted's Avatar
Resmarted
ouch @ last post.
if it helps there's some kind of electrical sensor box thingy (been a while since I've seen it) under the leather cover on the driver side (I think it's on the driver side). That's under the taneau cover (the thing that flips up to store your top).
Old Oct 15, 2011 | 07:36 AM
dudegetalife
Update:
Insurance wouldn't cover top since it was preexisting condition.
Nissan wants 8k in parts before they start work on it.
Got second opinion besides nissan saying top was installed improperly
Gonna more than likely go to court with upholstery shop.
Still dont know issue.
Old Jul 5, 2018 | 05:38 PM
Boderjoe's Avatar
Boderjoe
Default Soft top won’t go down
hi i see you had the same problem iam having at the moment my nissan 350z soft top wont go down not the window nothing do no sound at all. Can you let me know how you fix your problem with your car.. thanks
