Convertible top wont move at all
Old Oct 19, 2022 | 12:48 AM
  #41
tywon's Avatar
tywon
Default I need help!!
Originally Posted by msk59
You are welcome laneb101. Yes, car in neutral/park, foot on the brake with e-brake engaged, then the top opens after you unlatch at the front. The windows do go down if they are not down already. So I think you got it now. I dont drive my car that often and i built a garage for it and it sits in that heated garage most of the time. Since COVID almost two years ago, we have been working from home and not much to do. I do have a frontier that I use around town.
Can someone please help me figure out my issues with my top, when I first got the car the top would go 3/4ths of the way down before stopping and now when I hold the button the windows go down the seat move forward but then nothing happens from there, I hear the motor working but nothing moves and then when I do get it to move after a couple times pressing it it will only budge a little bit before stopping, the back lid will open but the top won’t lift
Old Oct 19, 2022 | 05:15 AM
  #42
Heel Til I Die's Avatar
Heel Til I Die
If everything is else is functioning properly and you can hear the 5th bow motor engaging, then it might be something with the 5th bow motor binding or the auto-closure wire being out of alignment.
Just a guess, though. As indicated by my post on 12-15-18, there are a number of things that have to go right in order for the top to function properly.
Old Oct 20, 2022 | 11:26 AM
  #43
tywon's Avatar
tywon
Thank you for the fast reply seriously! I will definitely take a look at this, my next question however is where exactly is that part located lol
Old Oct 21, 2022 | 05:22 AM
  #44
Heel Til I Die
I attached a couple documents which might help you out. One is the roof section of the FSM (RF) and the other is the TSB that was issued for the 5th bow not closing properly.
File Type: pdf
File Type: pdf
Old Oct 23, 2022 | 08:57 AM
  #45
tywon's Avatar
tywon
Thank you the help is really appreciated I’m gonna try to look at it when I get some time
Old Feb 8, 2023 | 01:29 PM
  #46
350yyj's Avatar
350yyj
SOLVED
I had an issue with my top not functioning, not even the pre-sequence actions were working (window roll down, seat incline). I took it to a mechanic and they found it had been water damage to the soft top module. Diagnosis below -
  • Electrical Diagnosis RO 23 Jan 19 90.00 360.00 Convertable inop Tech RO: Diagnose inoperative convertible top? Test powers / Grounds at module - OK. Test brake pedal switch operation - OK. Test roof raise switch operation - OK. Power windows noted not lowering and or passenger seat not moving forward. Suspect possible control module failure. Need more time to further confirm control module.
  • Electrical Diagnosis RO 23 Jan 19 120.00 240.00 Confirm control module failure. Tech RO: Confirm possible soft top module failure? Remove module and inspect. Found burnt traces on circuit board. Burnt traces lead to 5th bow actuator circuit. Powered actuator with auxiliary power supply - found that actuator unlocking and locking as it should. Also confirmed power window down request circuit and 5th bow raise/lower motor working correctly. Recommend replacement of soft top control unit.
  • Electrical Service RO 23 Jan 19 60.00 120.00 Install customer supplied control module Tech RO: Replaced soft top control module. After replacement found roof warning lamp now illuminated on dash. Roof still doesn't not open. Found power at switch now also although switch is not functional. Bypassed switch temporarily and was able to have power windows begin to roll down and roof automatically unlatch from locked position but then stops and does not continue from this point forward. Roof also doesn't relatch if close is requested. Roof needs switch on dash replaced and further diagnosis to determine why it doesn't continue to
  • Electrical Diagnosis RO 23 Jan 31 80.40 482.40 Diagnose incomplete convertable retraction Tech RO: Noticed windows retract upon command but roof and passenger seat do not move. Diagnose passenger seat first. Found seat not receiving command from module to tilt forward. Traced issue to corroded diode in wiring harness behind drivers seat in storage compartment. Corrosion was due to water pooling in storage compartment. Replaced diode with new item, retest, windows, seat and roof work as commanded. Note gas struts in roof not correctly mounted. Clips are missing. Temporarily secured in place with zip ties. Will need correct clips installed to prevent struts from popping off.
ritzthekracker
Jun 18, 2021 08:55 AM
msalsz
Apr 23, 2017 04:57 PM
BigJim
Apr 28, 2012 03:17 PM
chestuhr
Jan 31, 2010 06:20 PM
Jes-Z
Feb 25, 2009 07:33 PM
