Creaks in the Top when it is up
Old Dec 26, 2003 | 06:45 AM
jrofman's Avatar
jrofman
Default Creaks in the Top when it is up
I have noticed that whenever my top is up every time I drive over a bump I get huge creaks on the driver's side of the top, but not the passenger side. Anyone else have this? What would be your recommendation.
Old Dec 26, 2003 | 07:58 AM
Zeelicious's Avatar
Zeelicious
You are not alone, I have the same problem
Old Dec 26, 2003 | 12:04 PM
jrofman's Avatar
jrofman
As it is only on one side, the big question is, what to do about it.
I am still waiting to get my top replaced since there is a hole in it, but they are only replacing the fabric and the affected metal that caused it. I think i need a new top.
Old Dec 26, 2003 | 06:01 PM
ragtopz's Avatar
ragtopz
i have that problem too. i havent been able to locate it. i had the dealer take a look at it when they changed out my soft top, but they couldnt locate it either.
Old Dec 26, 2003 | 09:25 PM
350zRoadster04's Avatar
350zRoadster04
Same problem here. It is extremely annoying. Can't pinpoint the problem at all, but it is definitely coming from behind me on the driver's side.
Old Dec 27, 2003 | 03:09 AM
harester's Avatar
harester
I've haven't heard any creaking... but I only have 458 miles. If it's reall loud, that would be upsetting, but it is a roadster, so I'm willing to put up with wind & acouple of rattles
Old Dec 27, 2003 | 03:46 AM
EddieJr's Avatar
EddieJr
Mine creaks also, but I also have a Miata that makes the same noise.
The frame on soft tops are not very rigid and flex alot. So right now I'm not too worried about it.
Old Dec 27, 2003 | 12:44 PM
AndyB's Avatar
AndyB
Default Creaks
There are two places to look for creaks.
1st I would look at all the folding points in the top. I would just drip a LITTLE lube on each hinge point. Use something thin that will penetrate. Don't get any lube on the fabric.
2nd could the creak be coming from where the rubber gasket under the top sits on the body? I had a small creak there when it was cold outside. I just raised the back of the top, cleaned the rubber gasket and the mating surface, and then lowered the top again. Fixed it for me.
Old Dec 27, 2003 | 03:33 PM
350zRoadster04
Not sure about everyone else, but mine is more of a rattle than a creak. It rattles over small bumps in the road.
Old Dec 29, 2003 | 04:47 AM
harester's Avatar
harester
It's a regtop, it will have rattles, creaks, squeaks and more. Enjoy it for what it is, one fun car to drive.
Old Jan 2, 2004 | 08:07 AM
RedHerring's Avatar
RedHerring
I have a "tick" in the top on the left side just above my head. If I push up on the crossmember that runs over the top of my head it will tick. I found that if I put a bit of lubricant on the end of that crossmember where it sits against the frame that goes over the door the problem goes away for a couple of days. It is driving me crazy. WD-40 works best, lithium grease worst.
I also have holes in my top 3 of them to be exact. I need to get the top replaced.
Old Jan 9, 2004 | 05:22 PM
jrofman's Avatar
jrofman
Got my to replaced finally. Definetly quieter - no more holes. Actually I think it creaks less, but it might need some breakin time.
norrix420
350Z Roadster
May 23, 2022 05:11 PM
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
