Wheel fittment question
Old Apr 16, 2012 | 06:57 PM
bsc7080mzc's Avatar
bsc7080mzc
Default Wheel fittment question
We just purchased a 350Z Roadster (2006) earlier this year. I also own a 2006 Honda Civic Si sedan that I autocross with. I have a set wheels on my Si which has the same bolt pattern. They are 17x8 with an offset of 40+. I have 225/45/17 BF Goodrich KDWs wrapped around them. My wife's Z has Brembo's with 225/45/18 and 245/45/18 with stock chrome wheels and standard street tires.
Whew... okay. I would like to run the Z on a few fun runs this season, but I would prefer to avoid running on her stock setups. If the Si's setup will fit for one or two fun run's this season that would be great. Otherwise I will have to put off racing the Z until we get a separate rim/tire setup.
Old Apr 16, 2012 | 07:10 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
So you're asking if a 17x8+40 Honda Civic wheel will fit on the a Z with Brembos? I don't think so. Even if they cleared the front calipers (unlikely), I doubt the hub diameter is the same.
Old Apr 16, 2012 | 09:39 PM
Waiz's Avatar
Waiz
Read this thread:
https://my350z.com/forum/2003-2009-n...questions.html
Specifically this post:
https://my350z.com/forum/2487452-post8.html
You need to realize that you're asking if wheels and tires suited for a FWD car can be placed on a RWD car which is the biggest issue
Old Apr 16, 2012 | 10:50 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Apr 17, 2012 | 12:32 AM
terrasmak's Avatar
Test fit them, they will probably work. Ideal, NO , work, YES.
Old Apr 17, 2012 | 05:05 AM
BoomerZ33's Avatar
BoomerZ33
that's what i would do if i were in your shoes
Old Apr 17, 2012 | 05:06 PM
bsc7080mzc's Avatar
bsc7080mzc
They are aftermarket rims, so I have to use centric rings even for my Si. If the clearance was there then it would be just a matter of getting the centric rings to match it up with. So my main concern was the Brembos. I could always mount them and see if they rotate freely but figured it would best to ask first. Definitely nothing would stay on the vehicle. Just something enough to make one fun run.
Old Apr 17, 2012 | 05:09 PM
bsc7080mzc's Avatar
bsc7080mzc
That would also give me time to upgrade the stock clutch to a stage 1 as well.
Old Apr 17, 2012 | 05:11 PM
bsc7080mzc's Avatar
bsc7080mzc
That is what I was trying to figure out about the stock ones on the car. Pretty sure they are factory chrome rims but I will have to measure them for size and offset.
Old Apr 17, 2012 | 05:31 PM
bsc7080mzc's Avatar
bsc7080mzc
Originally Posted by Waizzz
Read this thread:
The links are very helpful. Answered many questions I hadn't asked yet. Noticed the link about the slip light coming on especially when using wheel/tire combinations not suited for the vehicle due to the dependency of the Z needing offset sizing of front vs rear.
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
