Brake warning light
Old Aug 3, 2012 | 03:09 PM
doorpro's Avatar
doorpro
Default Brake warning light
Hello all,
the brake warning light on the dash of my wifes '06 Roadster came on about a month ago so i immediately checked the fluid and it was good so the reservior/sensor wasn't the issue.
I then checked the front pads and they were quite low so i changed them which made the light go out for about a week.
I then checked the rear pads and they also needed changing and when i did that the light went out for about a week yet again.
Now i know that there must be a simple answer but it alludes me and i need help.
The fluid is at the correct level and all the pads are new so is there a reset procedure or some other sensor that i dont know about?
As usual any help will be gratefully appreciated.
regards,
Doug.
Old Aug 3, 2012 | 04:41 PM
Jennifer 2's Avatar
Jennifer 2
Doug, the brake warring light on my Roadster does double duty. It will indicate a low master fluid level (as you have investigated) and it also notifies when the hand brake is applied. It could be that you need to adjust the hand brake so that it closes the electrical switch in a more positive manor when you release the brake.
Old Aug 3, 2012 | 05:51 PM
doorpro's Avatar
doorpro
Default Oops
Hi Jennifer2,
I am sorry that i omitted telling everyone that i disconnected the handbrake switch because i thought that it might be an issue, so i am sorry but do appreciate your help.
regards,
Doug.
350z82
Oct 1, 2015 06:25 PM
